Greddy actuator Q
Old Oct 11, 2003 | 07:35 PM
95gsrturbo's Avatar
Default Greddy actuator Q
for some reason i cant get my greddy 18G to keep over 7psi , ive turned the Apexi boost controller upi and the duty cylce reaches 90%, it will run up to 14 psi then float back down , seems like once the wastegare opens it OPENS and cant keep still.
I dont understand- ive heard of people running 15+ lbs of boost on this kit and dont know why i cant.
does anyone know if its a problem with location of the WG or is it that i may have a weak actuator, -- will getting a 14lb actuator help,
and please dont recommend an external wg because i cant afford it and i dont feel like getting a whole new setup.
Old Oct 11, 2003 | 08:29 PM
maddog20's Avatar
Default Re: Greddy actuator Q (95gsrturbo)
Try plugging the Compressor port. And running the signal line to the Intake Manifold.
Old Oct 11, 2003 | 08:38 PM
BoostedITR41's Avatar
Default Re: Greddy actuator Q (maddog20)
it probably isn't your wastegate. it is probably your blow off valve leaking boost off
Old Oct 12, 2003 | 04:27 PM
95gsrturbo's Avatar
Default Re: Greddy actuator Q (BoostedITR41)
i checked the bov, no leaks tighted it down and changed the gasket too,
as far as the compressor port-- there isnt one on the greddy kit, only a port on the mani...
if you take off the WG line, (basicall send no signal back -- you should have infini-boost) well thats what happens, the boost spikes to around 20psi and we let off because we cant guarantee whats gonna happen. without having a stable boost pressure we dont know how to tune it---
if we set the boost controller to hold say 14psi, it will run up there, then fall back to 7 because the WG is just opening up too much, its like once it opens just a bit-- it slams open and the spring cant hold it closed--- im confused...
Old Oct 13, 2003 | 10:36 PM
95gsrturbo's Avatar
no replies, so no one here has this prob huh? must be a fluke?
Old Oct 15, 2003 | 03:51 PM
95gsrturbo's Avatar
bump
Old Oct 15, 2003 | 04:33 PM
falcongsr's Avatar
What is this crap?
i think you have some other problem. in order of likelihood:
too restrictive exhaust
too restrictive intake before turbo (did u remove the restrictor plate?) - also try a different filter.
exhaust leak around the turbo
something like that
Old Oct 15, 2003 | 04:37 PM
monkijunki's Avatar
Default Re: Greddy actuator Q (falconGSR)
hey, if u decide to upgrade the actuator, let me know. i need to replace mines cuz the connector for the vacumn line broke off =/ anyway, good luck with ur turbo, let me know if anything's up.
Old Oct 15, 2003 | 06:36 PM
Bailhatch's Avatar
Default Re: Greddy actuator Q (monkijunki)
my boost falls off like that too. my turbo is tiny and my exhaust and cat are stock.
Old Oct 15, 2003 | 08:56 PM
roydogg's Avatar
Default Re: Greddy actuator Q (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">my boost falls off like that too. my turbo is tiny and my exhaust and cat are stock.</TD></TR></TABLE>
You need to open up the air flow.
Old Oct 20, 2003 | 09:24 AM
95gsrturbo's Avatar
Default Re: Greddy actuator Q (roydogg)
well im running an Apexi N1 catback-- that may be the prob. Its 2.3" piping all the way -- i DO have a 2.75" DP from the greddy elbow including the flex pipe , up to the CAt-- then it bottle necks to the cat at 2.3" all the way back--
could this be the prob??
thanks
Old Oct 20, 2003 | 09:35 AM
Andrew 825SM's Avatar
I think many 18g wastegates have that problem holding high boost. No matter how much boost I run, it always ends up falling to 10 psi.
Old Oct 20, 2003 | 09:41 AM
95gsrturbo's Avatar
Default Re: Greddy actuator Q (Andrew 825SM)
well ive ordered a new one from majestic turbo -- when it comes in well find out what the issue is-- i hope i didnt just waste 100+ dollars on this and the prob is now my exhaust--- i figured the 2/3 was enough for now and i could upgrade later with more money-- but maybe not???
Old Oct 20, 2003 | 09:03 PM
95gsrturbo's Avatar
any other suggestions
Old Mar 17, 2004 | 11:51 PM
roydogg's Avatar
any luck?
PA MATT
Jul 16, 2005 08:10 AM
boostincoupe
Jan 24, 2005 02:31 AM
BDTURBO
Nov 5, 2004 08:05 PM
Kevin
Nov 18, 2002 10:05 AM
91CivicSi
Sep 24, 2002 07:31 AM
