got the turbo only want to run 6psi what alse do i need
Jus bought my 1st honda its a del sol d16 jus bought a turbo kit was looking to keep the car a daily n run 6psi but want to know what alse i need to bolt the turbo up besides what the kit came with..will i need a new map sencer.someone told me they make a spacer r somthing but dont qoute me on that..im not new to car's but def kind of new to the comp. lol..THANKS
Modified by lildelslow at 2:56 PM 1/27/2008
Man U FTW
First of all, PSI doesn't dictate anything. A power goal is a more practical way of determining what you want to do. On a stock B16, you could run ~300whp safely with a good setup and tune.
You'll need a new map sensor if you go over ~10.5psi...there are a number of turbos which can make a 300whp power goal and do it without exceeding 11psi. My GT3255b is an example of such...i made 315whp on my bone stock GSR at ~10-10.5psi
Re: got the turbo only want to run 6psi what alse do i need (lildelslow)
ok so found some more info n know i need the missing link.Its a spacer that goes under the map sencer.Do i need to do anything with my fuel system im not looking to gain a lot of power maybe get it up to 200whp what other prob. will i be looking at n any up coming prob. i may run into Thanks.
Put the turbo back in the box, put it in your closet, and do about a month of research before you continue. From your comments, it's clear you need to learn a lot. All of the questions you've asked can be answered by searching this forum. The FAQs in the Forced Induction section will be a good place to start.
The search button is in the top right of your screen. It's bold and red.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lildelslow »</TD></TR><TR><TD CLASS="quote">ok so found some more info n know i need the missing link.Its a spacer that goes under the map sencer.Do i need to do anything with my fuel system im not looking to gain a lot of power maybe get it up to 200whp what other prob. will i be looking at n any up coming prob. i may run into Thanks.</TD></TR></TABLE>
A missing link is a one way check valve so your map sensor see's vacuum but not boost. You need one of those depending on how your managing fuel.
The stock fuel pump will get you to 200whp easily, and if your only running 6psi on even a larger turbo it'll be fine. Xenocron's pumps are pretty cheap though, so get one of those.
DSM 450cc injectors, a chipped ecu, a fuel pump, and a tune is the easiest way. Missing links, FMU's, and AFC's are the "old" way of doing things anymore.
Make sure your kit is complete (maybe post some pics of everything), do some reading, get the ecu chipped with a basemap, then get your stuff installed and drive it to someone that can tune it. That's how you do it.
Man U FTW
Hold off on the build for a little while...read the FI FAQ and learn more about turbo setups. I guarantee if you rush through your build and half *** everything (which you will because you dont know all the little details just yet) you will end up blowing up something then starting over from square one...
1baddcivicsi
10-11-2006 10:09 PM
