good and secure compression ratio for b16a2 22psi setup
Old Aug 20, 2004 | 04:11 AM
hondaapi's Avatar
Default good and secure compression ratio for b16a2 22psi setup
I plan to go 22psi on my b16a2. What is the best cr for roundabout 450hp?
Where can I get the right pistons? I just know JE to order to Germany.
Old Aug 20, 2004 | 05:04 AM
m R g S r's Avatar
Default Re: good and secure compression ratio for b16a2 22psi setup (hondaapi)
CP pistons, 9.0 to 1, Race Gas.
Old Aug 20, 2004 | 05:29 AM
ogabudiah's Avatar
Default Re: good and secure compression ratio for b16a2 22psi setup (m R g S r)
Safety first, i would go 8.5-1, 8.8-1, or 9.0-1, fuel managment is imperative.
Old Aug 20, 2004 | 05:35 AM
G
sh!t happens.
Man i say get 9.8:1 c/r or 9.0:1 and you can make 350whp on pump gas. Its all in the TUNER!!!!!!! Dont base your numbers on psi. whats your whp goal? what turbo are you going to run? what rods? what engine mangement?
Old Aug 20, 2004 | 06:11 AM
hondaapi's Avatar
Default Re: good and secure compression ratio for b16a2 22psi setup (G"UNIT)
HP goal is round about 450hp. I want to take Eagle Rods.
Our managementsystem is comletely built on our own. You can regard it as a freeprogramable system, where we can change injection an ignition depending on boost - not just FMU or Apexi.
A Garrett T3 with internal Wastegate,Full-Race-Style manifold, Edelbrock-Intake-Manifold,3"Exhaust.....
But please think, here in Germany we have everywhere the possibility to ride very long distances with max boost and maximum speed and not just 1/4mile-races.
So I´m not sure what CR.
What do you think?
Old Aug 20, 2004 | 07:26 AM
mike1114's Avatar
I think you should IM a guy named austiantyper, I'm not sure of his screen name though, he lives in austria and drives a lot on the nurenburg raceway, (sorry if I spelled it wrong) so he knows a lot about what to put on your car to run boost a lot in high gears. Hes pushing like 450 to the wheels daily.
Old Aug 21, 2004 | 05:19 AM
vti2's Avatar
9:1 CP pistons
Eagle
Pauter
T3 is to small.
Use a SC61 or T3/T67 0r a T3/60-1
Old Aug 21, 2004 | 06:55 AM
B18C1CYA's Avatar
Default Re: good and secure compression ratio for b16a2 22psi setup (vti2)
and y are eagle rods please tell us
Old Aug 21, 2004 | 07:39 AM
Boostage's Avatar
Default Re: good and secure compression ratio for b16a2 22psi setup (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">and y are eagle rods please tell us</TD></TR></TABLE>
JDM BR33D
10
Aug 9, 2018 08:03 PM
EF9_TryMe
Apr 19, 2010 11:22 AM
hellcivic1996
Jan 22, 2007 05:58 PM
FBTuning
Jun 26, 2003 08:56 PM
Trajic
Jul 16, 2001 05:38 AM
