what compression ratio to run in a b18c1?
Old Jun 26, 2003 | 01:26 PM
FBTuning's Avatar
Default what compression ratio to run in a b18c1?
We're puttign our GSR block back together now, we've pinned the sleeves, have a new crank (the old one got taken out by a bearing), we have eagle H-beam stock length rods, and will be going with some ross pistons, the head is going to be basically stock right now, maybe a little porting for more flow, we want to aim for about 300-325 Bhp in the near future, and then go from there, what is a good comp ratio to go with? 8.5, 8.8, or 9? we're going to be using a t3/t4 setup, we just haven't figured out the exact trim yet, thanks in advance, adn also if anyoen has any suggestins or cmments, feel free to lend them
Old Jun 26, 2003 | 06:14 PM
J-Brooks's Avatar
Default Re: what compression ratio to run in a b18c1? (FBTuning)
I wouldn't go any lower than 9, unless you wanna feel pretty slow when ur not under boost... just my .02
Old Jun 26, 2003 | 06:18 PM
GSR_Hacker's Avatar
New User
9 - 9.5 will work great for your HP goals and not kill you out of boost...
Old Jun 26, 2003 | 06:25 PM
11psiTurboSI's Avatar
Default Re: what compression ratio to run in a b18c1? (GSR_Hacker)
go with 9.5:1
Old Jun 26, 2003 | 08:51 PM
Flamenco-T's Avatar
Default Re: what compression ratio to run in a b18c1? (9psiTurboSI)
I like 10:1, if you have a good tuner, I wouldn't worry running 10:1 CR
stan
Old Jun 26, 2003 | 08:56 PM
lazerus's Avatar
Default Re: what compression ratio to run in a b18c1? (Flamenco-T)
also a modified combustion chamber ala endyn mods & rollerwaves wouldn't hurt to reduce detonation problems
Bond
Jul 30, 2021 01:47 PM
hellcivic1996
Jan 22, 2007 05:58 PM
kory97
Dec 29, 2006 02:14 AM
GSRerrr
Apr 4, 2005 07:11 PM
swlabhot
May 13, 2003 07:58 AM
