Gauge questions
Old 02-26-2005, 12:09 PM
LSVtechnologytur...'s Avatar
Default Gauge questions
Hey i just had two questions about gauges. First, with an air/fuel gauge do you need a wideband/ does it hook up to the o2 sensor? and second, does anyone know if the Autometer carbon fiber gauges have a light in them?
tia
Old 02-26-2005, 12:30 PM
beepy's Avatar
Default Re: Gauge questions (vtec'n)
You need a wideband. The cheap A/F gauges don't actually tell you anything.
Yes, all autometer gauges have backlight.
Old 02-26-2005, 02:33 PM
PrettyLude's Avatar
the cheap autometer gauge is a light show.
the autometer is only light by the led, you can't use a wideband oxygen sensor with the autometer gauge because its designed to be used with a narrow band o2 sensor
Old 02-26-2005, 03:43 PM
PM-Performance's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">the cheap autometer gauge is a light show.
the autometer is only light by the led, you can't use a wideband oxygen sensor with the autometer gauge because its designed to be used with a narrow band o2 sensor</TD></TR></TABLE>
Actually you can . PLX makes a controller conversion kit for it. but i think you need the whole wideband set up for it
nfinitecc
10-24-2006 03:46 PM
eluder33
04-08-2006 04:18 PM
hondaguyexsi
10-08-2005 06:58 PM
onePOINTsix
12-25-2003 11:02 PM
Loco Honkey
11-10-2002 10:40 PM
Quick Reply: Gauge questions
