DP diameter?
Old Jun 9, 2003 | 08:54 PM
egg's Avatar
egg
Default DP diameter?
hey guys im about to make a downpiep for my turbo setup which consist of a T3/T04E. the exhaust discharge is 2.5" and so is the flange hole. should i use a 2.5" tube for my first bend coming out of the turbo and the expand it to 3" or should i just use 3" tubing from the flange?
Old Jun 9, 2003 | 10:43 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: DP diameter? (egg)
just run a straight 3". there is no need to bottle neck it.
Old Jun 9, 2003 | 10:50 PM
TwistedHatch's Avatar
Default Re: DP diameter? (MotorMatrix.com)
i was wondering the same thing, my t3/t04e has like a 2 1/4 inch outlet, is this odd?? the turbo is supposedly a turbonetics, it has a garret housing on the inlet and the exhaust side is the standard t3 with 5 bolt flange.......
Old Jun 10, 2003 | 01:25 AM
egg's Avatar
egg
well its not like im considering it to restricting it. i figure, since the outlet is 2.5", the 2.5" tubing will better direct the exhaust gases and provide a better transition. well i dont even care anymore cause im to lazy so ill just go with your idea anyways and make it 3"
that-guy
Welding / Fabrication
Dec 29, 2010 10:15 AM
SlowSOHC-T
Apr 22, 2007 07:20 PM
LilCivic04
Oct 27, 2005 08:50 AM
jason190
Apr 1, 2005 12:29 PM
cjb80
Feb 18, 2003 08:44 AM
