garrett ?
Old May 22, 2011 | 05:05 PM
bigtom388's Avatar
Default garrett ?
im looking for a garrett rebuild kit the only info i can find on the turbo is the following. the cold side housing says .60 ar m-24 and on the hot side housing it says L902 and m1 .63. the problem is there is different types of seal kits from gpop shop just need to know if anyone knows what one i will be needing thanks alot guys
Old May 22, 2011 | 05:28 PM
TheShodan's Avatar
Moderator
Default Re: garrett ?
Housings mean nothing. you need to measure the wheels/ turbine shaft to determine what it is you have. Or, best case is to send it to gpopshop.com and erase all doubt.
Old May 22, 2011 | 05:31 PM
bigtom388's Avatar
yea thats what ima end up doing sending it out rather be safe then sorry thanks for the response though
Old May 23, 2011 | 09:59 AM
303Turbos's Avatar
there should be a metal tag on the bearing housing with the turbo part number on it
Old May 28, 2011 | 03:40 PM
bigtom388's Avatar
i looked for the tag but it wasnt there
Old May 28, 2011 | 05:54 PM
303Turbos's Avatar
it's probably a clone and not a garrett, which means it's probably not that rebuildable
Old May 28, 2011 | 08:06 PM
TheShodan's Avatar
Moderator
Not having a tag is not conclusive at all. There are many aftermarket applications in the series that do not have tags on them, that doesn't necessarily mean its not a Garrett. (Hell, none of the ones I create ever have one.) Most OEM applications will have tags on the backplates, but most Aftermarket does not. Until we see some measurement information and pictures, there's really not a whole lot that can be done except to send it in to gpopshop.
Old May 29, 2011 | 10:11 AM
303Turbos's Avatar
ok shodan, how many aftermarket applications actually use garrett parts and not 'garrett-ish' parts? Everything is from the far east now and not from the mexico
Old May 29, 2011 | 01:41 PM
TheShodan's Avatar
Moderator
Actually, there are still plenty of applications from both Turbonetics and Precision that are out there that were created and sold when they were still under contract with Garrett at the time that they were made. (especially those turbos that were pre-2009). Name plates are mainly for OEM applications, and those universal applications that were popular enough to be pre-assembled,(such as the 57, 60 "trim", and the stage 3 turbine wheel package of the 60-1 all have the blue stamping plate of 46659 -XXXX) while the others do not. For example, the GT3540S Garrett turbocharger uses some standard OEM parts from the Garrett line-up, but because it is not a standard package like the 46659 series, they never had a blue or green (rebuilt) namplate stamp.
So again, unless we know more information, not having a nameplate does not mean its not a Garrett turbocharger..But it doesn't mean that it is either.
Old May 29, 2011 | 06:31 PM
Sikocivic's Avatar
I just rebuilt a Garrett T3/T4 using this kit. The kit covers several different turbos so you have a few parts that you may not need to use.
http://www.treadstoneperformance.com...4&phot_key=166
lsvtec_hatchback
May 27, 2012 04:06 AM
.RTErnie
Jul 2, 2007 04:32 PM
jononioo
Feb 1, 2006 12:00 AM
racinskittle
Jun 28, 2003 03:19 PM
AlphaKennyWun
Feb 16, 2002 09:52 AM
