garret or turbonetics
Old 04-02-2006, 07:20 PM
ek4__'s Avatar
Default garret or turbonetics
im looking to turbo charge my d16z6 with stock internals...i have a drag manifold and turbonetics wastegate. if i run turbonetics where can i find a t3/t04B? and if i get a garret will it work for my drag manifold? and which one would you recommand? i want speed but i also want to drive it around town.
Old 04-02-2006, 07:44 PM
Mugencrxsir1's Avatar
Default Re: garret or turbonetics (ek4__)
Yes garrett makes a t3/t04b for your set-up, it has the same 4 bolt exhaust collector flange as the turbonetics. I personally like the turbonetics, but garrett is a nice turbo as well. Do a google search online, or check out ebay.
Old 04-02-2006, 09:02 PM
ek4__'s Avatar
Default Re: garret or turbonetics (Mugencrxsir1)
cool thanks dude....
Old 04-03-2006, 11:23 AM
Bseriescivic5's Avatar
I am also interested in this debate, The garrett is basically the exact same turbo yet the turbonetics one is more expensive...... explain?
Old 04-03-2006, 11:50 AM
Blind_Attack's Avatar
Im a master destributor for both and the main reason i think Turbonetics is worth more is because it comes with a full 1 year warranty, no hassle. If your garrett goes, your stuck buying a whole new turbo.There also vey diffrent as far as actual performance. Garrett turbos hit very hard when they come in, turbonetics make just as much if not more power, but have a more linear feel to them. It mainly depends on reliability and what kind of driving youll be doing.
Old 04-03-2006, 11:57 AM
mike1114's Avatar
Default Re: (Blind_Attack)
Turbonetics are single ball bearing turbo's.
Garrett (except for the GT series) are thrust washer bearing turbo's.
Old 04-03-2006, 12:09 PM
Flr Power's Avatar
Default Re: (mike1114)
Go garrett GT series if you can afford. When properly installed, they last a very long time.
Old 04-03-2006, 12:22 PM
Default Re: (Flr Power)
Just get the best turbo from either company that you can afford, and meet your horsepower goals/spooling goal.
Old 04-03-2006, 12:50 PM
Man U FTW
Schister66's Avatar
personally i prefer Garrett on a purely aesthetic basis....
Old 04-03-2006, 03:17 PM
thanks guys, right now i am running a garrett t3 .42/.48 little guy on my stock b16a and it pulls great down low, but runs outta breath up top....
Old 04-03-2006, 03:24 PM
h22 civic's Avatar
Default Re: (Bseriescivic5)
garret
turbonetics
my experience
Old 04-04-2006, 07:52 AM
tekturbo's Avatar
Default Re: (h22 civic)
turbonetics uses garrett turbos n e way
Old 04-04-2006, 07:55 AM
all go teg's Avatar
Default Re: (tekturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekturbo &raquo;</TD></TR><TR><TD CLASS="quote">turbonetics uses garrett turbos n e way</TD></TR></TABLE>
not to doubt you, but do you have any proof of this?
Old 04-04-2006, 07:56 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: (all go teg)
turbonetics makes their own stuff. they used to use some parts from garrett but garrett killed their contract
Old 04-04-2006, 08:46 AM
spooncivic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Turbonetics are single ball bearing turbo's.
Garrett (except for the GT series) are thrust washer bearing turbo's.</TD></TR></TABLE>
so are you saying that ALL turbonetics turbos are ball bearing?
Old 04-04-2006, 11:37 AM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">
not to doubt you, but do you have any proof of this? </TD></TR></TABLE>
well the last 2 times i used the turbonetics dual bb turbos i had probs first was a twin turbo supra ,second was a civic ,the supra went tthrough 4 yes 4 turbos in 1 week the first set was sent back to turbonetics they confirmed sent me another set then again probs took them out put 2 precision turbos no probs at all the civic same thing bb turbo 1 month smokin like a banchee change to a precsion no probs again
their response to me was the bb are finiky with heat cycles maybe their non bb are better but i never used them
Tippyman
05-13-2006 07:09 PM
LilCivic04
08-18-2005 08:52 AM
HT Username
05-06-2005 09:55 PM
91cvcsi
06-04-2002 12:33 AM
boosted3g
10-24-2001 12:10 PM
Quick Reply: garret or turbonetics
