fuel pressure drop
Old Sep 11, 2009 | 05:20 PM
boost4s2k's Avatar
Default fuel pressure drop
my fuel pressure goes from 44-45 down to 30 and below during wide open throttle, this doesnt seem normal to me first turboed car help please
Old Sep 11, 2009 | 08:49 PM
srmofo's Avatar
Default Re: fuel pressure drop
fuel pressure should go up. What pump do you have? and a little more info on your setup wouldnt hurt.
Old Sep 11, 2009 | 10:35 PM
JrOz's Avatar
weird cuz that happened to me this week and i was like wtf??... i have a stock jdm type r with a jacksons racing superchager kit... aem fuel rail and regulator with 440 injectors... min went from like 42 to about 32 psi... i also have a walbro 255 fuel pump..
Old Sep 12, 2009 | 06:04 AM
boost4s2k's Avatar
i have a 255 pump i got with my turbo kit 650cc injectors have a synchronic fuel pressure regulator with stock fuel rail also my fuel pressure sensor is on my feed line not on the fuel rail
Old Sep 12, 2009 | 08:02 AM
Foowee's Avatar
I bet you city boys are using the stock wires to power your walbro. Go to the junk yard, get a few headlight relays. Go to the autoparts store get some blade connectors and about 10ft 10ga. wire.
Hook up the stock wires to the blades on the relay that have the little coil going between them on the diagram. Then run a long piece of the thick wire from the positive terminal of your battery to one of the switch side blades. Run another piece of thick wire from the other switch blade to the + on your pump. Run another thick wire from the - on your pump to ground.
Tell me if you have fuel pressure issues after doing so...
Old Sep 12, 2009 | 06:25 PM
jetspeedz's Avatar
i would stay away from those cheap bosch relays, there are much better heavy duty automotive relays. However i have rarely seen oem wiring issues to the pump.
Old Sep 12, 2009 | 06:46 PM
boost4s2k's Avatar
im gonna take the fuel up out tomorrow check it out make sure no wires are loose put my stock pump back in and if it starts and i have no problems with the pressure its the gas pump
Old Sep 12, 2009 | 07:09 PM
96 GSR-T's Avatar
i know this is a stupid question but do you have a vacumn line running to the regulator?
Old Sep 13, 2009 | 03:24 AM
Foowee's Avatar
The reason you haven't seen any oem wiring issues is because your car isn't running yet.
I've been using oem honda headlight relays for the setup I described for several years now. Stick to bikes... or come back with some real world experience after you get your car running.
Old Sep 13, 2009 | 06:49 AM
96 GSR-T's Avatar
There is nothing wrong with Bosch Relays, running 2 of them to both my pumps and I know several others using them as well...... Honestly I have never had a complaint about anything Bosch I even use their oil filters religiously and I will be running 2 bosch pumps this year too.
Old Sep 13, 2009 | 10:03 AM
jetspeedz's Avatar
lol funny, i was doing this over 10 years ago when it was just rev hard vs drag when you were probably never on the scene.. used oem wiring then and still didn't have issues.
Old Sep 13, 2009 | 10:56 AM
Foowee's Avatar
Okay, since you're the expert. Why is this guy losing fuel pressure?
Old Sep 13, 2009 | 12:27 PM
boost4s2k's Avatar
i think its a faulty fuel pump its on its way out ran the car for 3 hrs with out a problem then it started acting up pressure dropped 2 psi then another 2 and so forth had got out of the car and then when i got back it it was at 20something
Old Sep 13, 2009 | 12:52 PM
jetspeedz's Avatar
i would also look at the pump, if the wiring was bad the pump would probably not prime or it could cut out if its an intermittent short not drop psi like your describing.
Old Sep 13, 2009 | 03:45 PM
96 GSR-T's Avatar
check your fuel filter too......
Old Sep 14, 2009 | 07:40 PM
boost4s2k's Avatar
so i took out the pump and double checked everything wires were good put it back in so i messed with the fpr i put 2 vacuum lines one it from one source and when i boost now the fuel pressure goes up from 42 to 60 psi... so im guessing everything is fine
Old Sep 14, 2009 | 08:15 PM
jetspeedz's Avatar
glad you got it sorted out
Old Sep 14, 2009 | 08:18 PM
boost4s2k's Avatar
me too ive had head ache after head ache with it....thanks for the help
si90rex
15
May 18, 2010 05:03 PM
jaredvabeach
Aug 6, 2008 07:38 PM
Vtec-Mike
Jan 7, 2006 10:02 AM
Quade
Apr 22, 2004 06:33 AM
