average fuel pressure
Old Sep 25, 2009 | 04:23 PM
Kr4nG's Avatar
Default average fuel pressure
hey guys i was just wondering what kind of fuel pressure should i have with a walbro 255 fuel pump, stock rail, and precision 525cc injectors on a stock gsr turbo. and i also have the stock fuel pressure regulator. is 60 to 65 to much?
Thanks
Old Sep 25, 2009 | 04:29 PM
Sr420Det's Avatar
Default Re: average fuel pressure
around 50 psi is stock so thats where u should be
Old Sep 25, 2009 | 04:34 PM
B16Drag's Avatar
60-65 when? 60-65 at idle is on the high side. At idle, stock should be around 42psi. Mine's always hoovered 40-45psi.
Old Sep 25, 2009 | 05:39 PM
Kr4nG's Avatar
yea i dont understand why its so high when i only have the stock fuel pressure regualtor with a fuel pump and injectors. the car isnt tuned yet so i guess i need to go and get a adjustable regulator before. and its running rich too.
Old Sep 26, 2009 | 07:00 AM
ef92b's Avatar
check your return lines. might be pinched somewhere.
Old Sep 26, 2009 | 08:38 AM
BbqEazyE's Avatar
running that pump with bigger injectors on your car will be pushing a lot more fuel thru. Thats why pressure is so high. Get the regulator and adjust before the tune. Thats my .2 cents
Old Sep 26, 2009 | 08:42 AM
sgnlab's Avatar
should be 42psi @ idle!
Old Sep 26, 2009 | 12:10 PM
Kr4nG's Avatar
ok thanks guys can i mess something up real bad untill i can get one? i want to go for a test drive i just got the car finished.
Old Sep 26, 2009 | 01:30 PM
damndan23's Avatar
im runnin a single walbro intank to a bosch 044 to injector Dynamics 1000cc injectors and a crappy B&M FPR.. when warmed up and idling right my Pressure is or can get as low as 20-25psi... when im barely on the throttle drivin down the HWY @ 3k rpm its about 65psi then when i get into the throttle a lil bit more the needle will jump up n bounce off of 80psi n settle around 75psi. .. my old setup was similar to yours but with RC-750's my FP was the same if not a few psi higher than what ur seeing now
Old Sep 26, 2009 | 02:41 PM
Kr4nG's Avatar
ok thanks for all the help. because i know im running rich but its just till i see my tuner in the next few weeks. i just finished the car like yesterday. Im just curious if i should spend some more money on a regulator.
Old Sep 27, 2009 | 06:30 PM
b20beast83's Avatar
i run 55psi base pressure
Old Sep 27, 2009 | 08:22 PM
ls_on_boost's Avatar
i also run 50 psi aeromotive fpr and precision 1000cc injectors
Old Sep 27, 2009 | 08:40 PM
komat's Avatar
if hes getting tuned, it doesnt really matter whats his psi is. it just has to be stable
Old Sep 28, 2009 | 02:31 AM
Kr4nG's Avatar
yea im sure its stable at 65-70 but is it still safe to drive the car till i see him? can more fuel hurt my motor?
GsrIntegra789
Jun 4, 2008 04:00 PM
aalb1
Nov 2, 2005 10:47 AM
IntegraTypeR
Aug 25, 2004 08:34 PM
Leo95SE
Jun 24, 2002 01:03 PM
