Fuel Management opinions/help needed...
Old Mar 24, 2003 | 03:50 PM
01ITR#700's Avatar
Default Fuel Management opinions/help needed...
Ok here's the deal, I'm ready to purchase and install my fuel management system...I have tons of options but wanted some additional input from you guys...I just did the upgrades listed below...
-The car: 2001 Integra Type R
-The Motor: Stock block, 9.0-1 Arias Pistons, Inline pro Block guard, new stock Headgasket, stock head and Intake manifold
-New clutch went in at the same time Pistons went in
-The Turbo: Rev Hard manifold, Turbonetics T3/60-1 HIFI, custom piping and Intercooler
This turbo setup on the stock motor @ 7.5psi made 282whp and 198 ft. tq. with a 12:1 FMU and inline pump.
So I want info and suggestions on what to do for my next fuel management setup with my new motor setup/compression etc.
Thanks a lot.
M
Old Mar 24, 2003 | 05:00 PM
boosted hybrid's Avatar
Default Re: Fuel Management opinions/help needed... (01ITR#700)
Your best bet would be to run hondata s100 w/boost, 720cc injectors and walboro 255lph fuel pump. This fuel system will support around 400whp. Leave fuel lines, rail and fpr all stock.
Old Mar 24, 2003 | 07:01 PM
tegasaurus's Avatar
Default Re: Fuel Management opinions/help needed... (boosted hybrid)
how much is s100 with boost and where can it be found? im in the market.
thanks,
Ryan
Old Mar 24, 2003 | 07:51 PM
1.8T_EG's Avatar
Default Re: Fuel Management opinions/help needed... (tegasaurus)
... i am rebuilding my motor in the next month with a similar setup... i am considering either hondata s100b or the uberchip from uberteg...
Old Mar 24, 2003 | 08:19 PM
Kyle from ks-motorsports has a killer deal on the s100 with boost. I dont want to say how much on this post since the prices arent supposed to be out in the public since they are so good.
Old Mar 25, 2003 | 04:22 AM
01ITR#700's Avatar
Thanks for all your information and help so far. So Hondata is indeed the only way to go at this point??
M
Old Mar 25, 2003 | 04:38 AM
SEFIxCivic's Avatar
how much do you want to spend?
Old Mar 25, 2003 | 04:41 AM
01ITR#700's Avatar
Default Re: Fuel Management opinions/help needed... (SEFI8LOxCivic)
Not real sure yet, best bang for the buck basically. I'm not rich by any means, so money is an issue.
Thanks.
M
Old Mar 25, 2003 | 05:05 AM
swlabhot's Avatar
Stock rods?? Why did you not put in some rods while the pistons went in?
Old Mar 25, 2003 | 06:09 AM
01ITR#700's Avatar
Default Re: Fuel Management opinions/help needed... (swlabhot)
Several reasons, mainly $$. And I'm not planning on going too while and crazy with this setup.
M
Old Mar 25, 2003 | 06:17 AM
swlabhot's Avatar
Nice # btw I presume your compression is stock? What is your timing retard? At the dizzy?
Old Mar 25, 2003 | 06:21 AM
01ITR#700's Avatar
My previous setup was stock compression, stock timing etc...The new pistons, block guard, and clutch are all installed, just deciding on fuel now...
M
pushr0djunk
Feb 17, 2003 12:49 AM
1.8T_EG
Feb 13, 2003 09:08 PM
X2BOARD
Mar 22, 2002 05:09 AM
MugenSi00
Dec 2, 2001 10:55 AM
