What your fuel system setup?
Old Nov 28, 2001 | 04:10 PM
MugenSi00's Avatar
Default What's your fuel system setup?
I'm in the process of prepping for my turbo setup going in after the winter. I'll be going with the max rev kit (once released) and AEM stand alone (once released) on a fully built block and head in hopes of running 10 psi low and 24 psi high. I recently purchased a Walbro 255 lph/hp fuel pump and I'm trying to decide on injectors. RC 720 cc's are more then likely the way I'll go, but I want to see what everyone else is running.
[Modified by JuicedSi, 7:11 PM 11/28/2001]
Old Nov 29, 2001 | 11:46 AM
sgT's Avatar
sgT
Default Re: What's your fuel system setup? (MugenSi00)
Replace all of your fuel line with -8 or -10, ditch that tiny walbro and get a real
fuel pump. 720cc injectors are a minimum
Old Nov 29, 2001 | 11:57 AM
SiR Kid's Avatar
New User
Default Re: What's your fuel system setup? (sgT)
I've got
Z-DYne Gold w/ p166 laptop
Venom 550cc's for a GS-T Eclipse
Holley 255 LPH <maybe GPH?> upgrade for Eclipse GS-T
Stock Lines
Stock Filter <soon to be a high flow inline>
Stock Rail
Stock FPR
I'm at 8-9 PSI Low boost, want to make 16-18 High Psi once we can get it moving again <damn stock tranny's> and on the Dyno.
Old Nov 29, 2001 | 11:58 AM
Liltrix's Avatar
I am using a modified stock fuel tank, Aeromotive 1000cc pump, Aeromotive inline filter, -8 and -6 braided fuel lines, Paxton FPR, AEM fuel rail, 720cc RC injectors, and a DFI Gen 7. Here are some pics. http://community.webshots.com/user/cojoo
[Modified by Liltrix, 3:58 PM 11/29/2001]
Old Nov 29, 2001 | 12:09 PM
VTC_CiViC's Avatar
Default Re: What's your fuel system setup? (Liltrix)
Walbro 255lph pump
RC 440cc injectors
V-AFC
Old Nov 29, 2001 | 12:19 PM
MugenSi00's Avatar
very nice setup. I'm glad to see you went with 8 gauge wire to feed that beast. I may follow in your foot steps here.
Old Nov 29, 2001 | 12:20 PM
TurboSedan's Avatar
New User
Default Re: What's your fuel system setup? (VTC_CiViC)
My setup will be:
Hondata Stage 2B
RC 440cc injectors
AEM FPR
Walbro 255lph
Old Nov 29, 2001 | 12:25 PM
Turbo EG6's Avatar
New User
Default Re: What's your fuel system setup? (97CivicFerio)
My Set-Up:
-8 Feed
-6 Return
Aeromotive Pump
Aeromotive Regulator
Speed-Pro (FAST System)
1000cc injectors
Old Nov 29, 2001 | 12:54 PM
Liltrix's Avatar
Default Re: What's your fuel system setup? (Turbo EG6)
Old Nov 29, 2001 | 01:06 PM
SiRkid's Avatar
holy shnikies..you guys are pumpin mad fuel
Old Nov 29, 2001 | 01:10 PM
Smashback's Avatar
You should use solid aluminum wall fuel lines under the car rather than braided. It's much cheaper, bends easily, and is the right way to go!
Old Nov 29, 2001 | 03:10 PM
SiR Kid's Avatar
New User
Default Re: What's your fuel system setup? (mplex2000)
Fuel will eat away at aluminum over time, no? Why use the aluminum beside to plan on replacing it after a few years?
Old Nov 29, 2001 | 04:17 PM
TurboInteg95's Avatar
My setup is a walbro intank pump with a 12:1 FMU, stock injectors, and 15 psi of boost.
Old Nov 29, 2001 | 04:21 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What's your fuel system setup? (TurboInteg95)
Liar...
Old Nov 29, 2001 | 06:05 PM
DA666's Avatar
Default Re: What's your fuel system setup? (Arturbo)
r u really using intank with 12:1 rising rate on stock injectors running 14 psi or is arturbo right? just wondering cos i wanna do cartech fmu with inline cos i thought the intank wouldnt cut it.....?
Old Nov 29, 2001 | 06:08 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What's your fuel system setup? (T3T4DA6)
He is being very sarcastic. TurboInteg95 and I are totally against the walbro with a high rising FMU.
art
Old Nov 29, 2001 | 06:13 PM
Giuseppe's Avatar
LOL
Liar...
i was just about to say..!!! and here he is telling me
to buy a bosch unit...lol
Old Nov 29, 2001 | 06:15 PM
Giuseppe's Avatar
T3T4DA6:
cartech fmu and bosch inline is my setup too..!!
its as better way to go..
Old Nov 29, 2001 | 06:27 PM
Hispeed's Avatar
-8an stainless steel braided feeder
-6an stainless steel braided return
aeromotive external pump
aeromotive fuel filter
aeromotive fuel pressure regulator
str fuel rail
rc 850 cc injectors
Speed Pro to control the fuel
Old Nov 29, 2001 | 07:26 PM
Smashback's Avatar
Default Re: What's your fuel system setup? (SiR Kid)
No, that's incorrect. Your motor is made of aluminum you silly Si driving person. I always used aluminum tubing for the fuel lines on all my "old sk00l rides" and never had any problems.
Old Nov 29, 2001 | 08:08 PM
LsTurbo91's Avatar
Lets see:
Zdyne ECU
Denso 440's
MSD inline/intank
Old Nov 29, 2001 | 08:11 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: What's your fuel system setup? (LsTurbo91)
Gonna be:
Vortech 8:1 FMU
Walbro High Pressure intank Fuel pump
RC 310cc Injectors
Old Nov 29, 2001 | 08:21 PM
bigTom's Avatar
in the future...
aeromotive pro pump, filter and regulator
-12 lines to pump, -10 to rail, -8 return
890cc injectors
Old Nov 30, 2001 | 07:30 AM
98Psi ITR's Avatar
Default Re: What's your fuel system setup? (ek9t)
bigger injectors => less fuel pressure ?
I see 700+ sizes, but why. 550 not enough?
Old Nov 30, 2001 | 07:49 AM
joeyitr309's Avatar
New User
Default Re: What's your fuel system setup? (98Psi ITR)
255 lph pump
rc 720
power fc
