Fuel Management with Integra Turbo
I have a 1995 Integra GSR. I am boosting about 5.5 psi and I just bought a Apexi VAFC 2 and a AEM wideband. Will I actually need bigger injectors with this little bit of boost? I don't plan on dragging it, it's only an every day driver that I want to be faster. I do not have the vafc or the wideband installed as of yet but I am working on it. The turbo is a t3/t4 AR63/AR50. Thanks for the help.
Man U FTW
yeah you're going to need something to control the fuel......and since you already have to tune it, you may as well crank up the boost a little....at least to about 8psi
Re: (Schister66)
BUt what about the injectors. If I do tune it do I have to have new injectors on a GSR. Are the factory ones fine? I think I may just hook everything up and then see how lean I am running without the injectors. Anyone else have a better idea?
