getting 370 cc injectors and vafc good idea?
B A N N E D
hey wuts up guys im finally getting my turbo setup this week it consists of t4 turbo manifold, turbo timer, bigggg front mount intercooler, hks wastegate and turbo xs BOV........i just have one question this week i bought rc 370 cc injectors and i got my apexi v-afc and a manual boost controller i picked up.........i should b fine on fuel if i only want to boost 6-8 psi for now correct...i was told it would b fine even better than a fmu
Re: getting 370 cc injectors and vafc good idea? (brandond)
Not sure what your question is? VAFC is not the BEST fuel management, but for that setup and 6-8psi it will be fine. There IS better out there, but that's up to you.
B A N N E D
Re: getting 370 cc injectors and vafc good idea? (SICKSOLVTEC-T)
yeah buddy i went to bristol dyno and i talked to this guy i forgot his name and he was saying if i run that apex vafc and 370 cc injectors i should b a ok on 6-8psi all day so im gonna run that until i get some dough for the 550's and hondata
Make sure you do some tuning on a dyno when you first put it all together. You may need to play with your fuel pressure a little.
B A N N E D
Re: getting 370 cc injectors and vafc good idea? (b16ahybrid)
yeah i got one more question when i do put it all together this week is it safe to drive it to the dyno on like 6psi but try not to step on it on the way there and then tune it
Yeah I would recomend leaving the stock injectors in and driving (without boosting) to the tuner. Thats what I had to do.
