help wit injectors
Old Aug 12, 2003 | 04:47 PM
ek9vboi
Guest
Posts: n/a
Default help wit injectors
i just got a new drag gen 3 turbo kit for my d16y8. it has fuel management, but i want more outta my car, so im planning to put injectors in and runa vafc with it. can someone tell me what injectors i should use and what is the difference between 390cc and 450cc or whatever they are.
Old Aug 12, 2003 | 04:53 PM
grndcont's Avatar
Default Re: help wit injectors (ek9vboi)
the #'s 310, 450, 550 ect are flow ratings of injectors @43 psi + there max duty cycle. a vafc is a crude way of controling bigger injectors for boost, but it is still much better than a fmu. 450's might be on the uncontroleble side of things for you, but 310's arnt that much bigger than stock. you might want to do some back-reading of post's involving the aem ems or the hondata systems. they are the correct way of doing things. and yes u can afford them, there is a hondata 4b on ebay right now for $400.
Old Aug 12, 2003 | 04:55 PM
Sinner's Avatar
if your going getto you can get the 450cc blue tops from dsm turbos cars or 310cc from ford probe turbo cars. 450cc flows more fuel than a 310cc.
Nick
Old Aug 12, 2003 | 08:23 PM
ek9vboi
Guest
Posts: n/a
any1 else?
Old Aug 12, 2003 | 08:41 PM
Happyman's Avatar
Default Re: (ek9vboi)
If you're doing the VAFC hack then get the DSM 450CC injectors. And by the look of your username you have an EK sooooo you will need an early honda resistor box. Go read up on the VAFC hack.
Old Aug 12, 2003 | 09:30 PM
ek9vboi
Guest
Posts: n/a
i figured that. to think of it i might go hondata. if anyone is selling one for cheap please give me a line. more info please!!!
Old Aug 13, 2003 | 04:11 AM
Happyman's Avatar
Yea but then you have to convert to OBD1 :-[
Old Aug 13, 2003 | 07:37 AM
baphomet's Avatar
Default Re: (Happyman)
If you need a resistor box or clips I sell them. fyi
Old Aug 13, 2003 | 05:22 PM
ek9vboi
Guest
Posts: n/a
i have the obd1 convert harness and ecu already, no big deal.
Turboredteg
Jan 26, 2005 01:17 PM
96redgsr
Jul 21, 2004 09:46 PM
turbo89civicb18hatch
Mar 17, 2004 08:56 AM
B17aTrbo
Sep 16, 2002 08:12 PM
SpeedMonkeyRacing
Sep 7, 2002 08:13 AM
