Fried turbo?
Old Dec 24, 2004 | 01:13 PM
B6tPoweredMx3's Avatar
Default Fried turbo?
Now im 99% sure my turbo is fried, it makes 14 lbs fine but at about 4k it starts to make almost a howling sound, not high pitched but almost as if its rubbing against something (the housing), now my question is anyone know of a good place in Upstate ny to have your turbo rebuilt? and maybe an around about price?
Turbo is a vj-14 blades look good.
Old Dec 24, 2004 | 01:50 PM
CivicEJ1's Avatar
Default Re: Fried turbo? (B6tPoweredMx3)
jiggle your compressor blades to see if it has any shaft play...could just be something else doing it.
Old Dec 24, 2004 | 02:05 PM
t04ecvc's Avatar
Default Re: Fried turbo? (CivicEJ1)
Is it smokin like crazy? You sure its not your wastegate? If the blades were rubbing on a housing or something, it would be obvious when you looked at them. Good luck.
Merry Xmas
Old Dec 24, 2004 | 02:14 PM
Default Re: Fried turbo? (t04ecvc)
no no smoke i sat there and reved the snot out of it all i smeel is gas no white smoke no blue.it dosent make the sound when not in boost but it does when its in boost, there is some side to side play but no in and out (that i can detect) now when you cay wastegate how can i check to see if it is?
Old Dec 24, 2004 | 06:10 PM
bump
Old Dec 25, 2004 | 06:37 AM
merry christmas bump
Old Dec 25, 2004 | 08:45 PM
t04ecvc's Avatar
Well, if its at full boost and the wastegate opens, it will howl if vented. I dunno if you just got the kit or anyhting so I just threw the question out there. Usually a bad turbo will smoke like hell.
Old Dec 26, 2004 | 05:34 AM
b18bturbo's Avatar
any turbo that is going to be bad or fried would actually smoke is one issue oil will be in thedownpipe and turbine and compressor sections. The other thing you will notice is the blades would be scarring the housings or rubbing against it. If if not that then it is something else in your setup
Old Dec 26, 2004 | 09:57 AM
Default Re: Fried turbo? (b18bturbo)
ok well i found out i have a blown headgasket is it safe to assume that it could have been the head gasket?If not time to go over it with a fine tooth comb again, it starts to howl at 4k and im making full boost at 2800, so what do you guys think it could be? Could a vaccum leak do this? maybe timing? i know the turbos getting oil and coolant and its also returning both oil and coolant to the block.
Any help is appreciated.
-Rynn
Old Dec 26, 2004 | 04:22 PM
bump
97boostedteggy
Apr 18, 2016 11:39 PM
allmotor_dm
Jan 24, 2006 06:07 PM
b00stedbyFastrax
May 11, 2004 02:55 PM
1.8T_EG
Aug 7, 2003 07:30 PM
TurBoXBirD16
May 10, 2003 11:47 AM
