Forged piston sounds.
Old Jun 23, 2003 | 01:21 PM
  #26
VanHonda's Avatar
Default Re: Forged piston sounds. (gtcali)
I have the wiseco pistons w/ eagle rods, and it does the same thing..not as bad after it warms up, but its still there, but not at all rpm's.
Old Jun 23, 2003 | 01:37 PM
  #27
Flamenco-T's Avatar
Default Re: Forged piston sounds. (VanHonda)
my wiseco/eagle setup never knocked, did you checked the piston skirt to wall clearances ? I had done all at .0025 and I recently took the pistons out of the motor and not a single scar from overheating or too tight of a clearance
Do it right, you'll save your pistons, no knocking due to slap
stan
Old Jun 23, 2003 | 01:39 PM
  #28
DragEG6 FI's Avatar
Valve adjustment should fix you right up...
Old Jun 25, 2003 | 10:04 PM
  #29
gtcali's Avatar
Default Re: Forged piston sounds. (DragEG6 FI)
Whoa..this post came back from the dead.
I figured out what was wrong.
My orignal post said I started hearing it after I installed my 450cc injectors and a VAFC (hack without the turbo). It turns out that this is the timing issue when running the hack. At around 2-4K rpms the hack advances the timing a lot. I was getting slight detination.
Found this out on homemadeturbo.com
Old Jun 25, 2003 | 10:12 PM
  #30
MiraiZ's Avatar
Glad you caught before something bad happened
b20vtech
Dec 25, 2005 07:08 AM
Ri5e
Sep 1, 2002 06:26 AM
GruvyTune
Aug 30, 2002 12:54 AM
turboex
Apr 8, 2002 01:37 PM
