Custom Downpipes
Old Jun 25, 2003 | 10:47 PM
lazer's Avatar
Default Custom Downpipes
I've got a T25 off a S13 SR20DET motor and an HKS cast manifold for my B16. I need a downpipe and it looks like the standard ford T3 flange isn't going to work so that scatches out using a Maxrev or Drag downpipe. It's a tight fit with the A/C compressor but there is enough room to put a downpipe on. What I need to know is if there is someone on the board who's a good welder and has a jig (or at least dimensions) to make a downpipe for me. I have the flange and will be taking multiple pictures with the manifold and turbo on the block (dimensions too) so fitment will not be a problem. I'm looking for a setup with a 2" main tube and 1" wastegate tube that meet up in a 2.5" downpipe that tapers to attach to the stock cat. It would also be nice if a plate could stick out from the flange to seperate the wastegate (internal) flow from the turbine flow. I have the gasket for the flange and will send that to whoever can make the downpipe. If you can help please email me. lazersos@sprl.db.erau.edu thanks
Mods- Bump this to the WTB section if you feel it's a better place for it.
GeeGee
Welding / Fabrication
14
Jul 5, 2007 09:28 AM
99B16Si
Nov 17, 2006 06:27 AM
dominate9
May 26, 2006 02:24 PM
88crxvtec
Jan 5, 2006 05:04 PM
menkio
May 21, 2004 04:40 AM
