fmax install
Old Nov 9, 2002 | 11:41 AM
ketchup_gsr's Avatar
Default fmax install
hi, i was wondering if anyone knew what to do with the replacement MAP sensor they give in the kit. Are we supposed to hook the map electrical and vacuum lines into this new sensor and just leave the old map sensor unconnected? Thanks, i think this is for tne MF2 install...
Old Nov 10, 2002 | 01:46 PM
MiraiZ's Avatar
Default Re: fmax install (ketchup_gsr)
You're suppose to splice it with the stock MAP sensor and then hook it into the MF2.
Old Sep 6, 2004 | 10:17 AM
Benjithx's Avatar
ok i have heard two different things, to splice it into stock map(above), and also not to splice it. does anyone know what to do here and if i have to splice it or not. And if i do have to splice it what wire where. thanks
Old Sep 6, 2004 | 12:08 PM
Blue Streak's Avatar
Default Re: fmax install (Benjithx)
i installed one a couple of years ago but never spliced into the stock map sensor. the supplied map sensor was wired into three of the mf2 wires i cant remember which ones though.
Old Sep 8, 2004 | 08:50 PM
PrettyLude's Avatar
that replacement map sensor is wired for the two additional injectors to come on when they see boost. You still will have to run the stock map
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
EK k kay
Nov 2, 2006 01:04 PM
1.8T_EG
May 12, 2003 09:58 PM
ketchup_gsr
Nov 9, 2002 01:02 PM
austrian type-R
Sep 1, 2001 05:16 PM
