turbo stutter?
Old Sep 6, 2004 | 12:05 PM
JustinL's Avatar
Default turbo stutter?
i have a d16y7 with a greddy 19t turbo at 11 psi, rc 310 injectors, e-manage and e-01, eagle rods, je pistons, and webcam turbo grind cam. right as im about to go from vacuum to boost at anything less than full throttle, the car stutters till it builds about 3 pounds, then it works fine. is this normal or is something wrong?
also i have a missing link on the maf sensor. is there anything else i can use or do to keep my car from showing check engine lights?
Old Sep 8, 2004 | 08:52 PM
PrettyLude's Avatar
i think you don't have to use the missing link if you are using the e-manage.
The stuttering you are experiencing, is from running way too rich at the point of stuttering
zerovandez
May 4, 2012 09:06 AM
myst0ryman
Mar 27, 2006 06:38 PM
cluelessmale
Jan 29, 2006 04:59 PM
CivicRaping
Apr 15, 2005 11:08 PM
B18 CYA
Apr 12, 2004 08:13 PM
