Fluttering BOV
Old Apr 23, 2004 | 12:32 AM
Vtec92Civic's Avatar
Default Fluttering BOV
I highly doubt it's bad, but I was just curious . . . . I use to have a typ s bov, but I sold it with my last setup, and picked one up from "SIMPLE" but it flutters like (something fast is flying away) like a bird or something or a dog shaking off, is that normal, or bad? My last Type S made a nice whistle.
Old Apr 23, 2004 | 12:39 AM
quik sol's Avatar
try adjusting it? a friend of mine had it and he adjusted it and it whistles...
Old Apr 23, 2004 | 01:17 AM
mskibbz-T's Avatar
Default Re: (quik sol)
Get a stronger vacuum source, tap the brake booster if you haven't already. That should clear it up
Old Apr 23, 2004 | 04:53 AM
Dr Honda's Avatar
Default Re: Fluttering BOV (Vtec92Civic)
I bought a cheap eBay BOV. it fluttered. so I slowly cut coils off the spring untill it blew off clean. (half a turn at a time) in it's instructions it said it was raited at 30 psi. I only run 10 so I didn't need the pressure of the spring that they suplied.
Old Apr 23, 2004 | 06:51 AM
quikB18B's Avatar
Default Re: Fluttering BOV (Dr Honda)
Try adjusting it first, if that doesnt work then give it a better vacuum source. however If your last one sounded fine, then it's probably just tightened to much.
Old Apr 23, 2004 | 07:09 AM
Burke's Avatar
Banned
Default Re: Fluttering BOV (quikB18B)
that fluttering is compressor surge
Old Apr 23, 2004 | 11:34 PM
Default Re: Fluttering BOV (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">that fluttering is compressor surge</TD></TR></TABLE>
and what exactly would that be? I have heard a ton of cars that have fluttering BOV's, but my last BOV didn't do that, so can someone clear up what compressor surge is? is it extremely bad?
Old Apr 23, 2004 | 11:49 PM
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec92Civic &raquo;</TD></TR><TR><TD CLASS="quote">
and what exactly would that be? I have heard a ton of cars that have fluttering BOV's, but my last BOV didn't do that, so can someone clear up what compressor surge is? is it extremely bad?</TD></TR></TABLE>
So you are boosting and you have all this pressure in your charge pipe, then when you let off the throttle and shift gears the throttle body closes and your turbo pushes against all of that built up pressure in the charge pipe which is very hard on the turbo internals and causes the compressor surge that you are hearing. The BOV vents the pressure in the charge pipe when the throttle body closes.
Old Apr 24, 2004 | 01:03 AM
Default Re: Fluttering BOV (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">
So you are boosting and you have all this pressure in your charge pipe, then when you let off the throttle and shift gears the throttle body closes and your turbo pushes against all of that built up pressure in the charge pipe which is very hard on the turbo internals and causes the compressor surge that you are hearing. The BOV vents the pressure in the charge pipe when the throttle body closes.</TD></TR></TABLE>
Thanks I remember what it is now . . . how can I fix it? I believe my BOV is Ghetto Rigged. I baught it off "SIMPLE" not to say he's a bad seller, but I kinda expected it to work yah know :-p
can someone help me out? here is a pic of it, and Ic an get more pics if needed.
Old Apr 24, 2004 | 06:57 AM
AlphaKennyWun's Avatar
yup I always thought the flutter was the bov but its mainly the compressor. I took off the filter for a while and it reduced fluttering 80%
Old Apr 24, 2004 | 07:16 AM
Rory Breaker's Avatar
Default Re: Fluttering BOV (Turbo Chris)
Just to clarify, the HKS SSQ should flutter in vacuum and sometimes at low boost, correct?
Mine flutters in those circumstances, and as I understand it thats normal. If I give it good throttle it chirps.
Old Apr 24, 2004 | 07:25 AM
quikB18B's Avatar
Default Re: Fluttering BOV (newgsrdriver)
Here's another tip, you want your vacuum lines as short as possible, From looking at the pic it looks like you could cut some slack off that line. Have you adjusted it yet?
another thing that will cause this is if your Bov isn't gettign a good supply of vacuum. Example if you have 3-4 things tapped into the one vacuum line(FPR) and you have the bov last in line this will also cause your BOv to flutter due to a lack of vacuum.
I would follow these steps,
1) cut some slack off that vacuum line
2) Make sure the Bov is getting a good source of vacuum
3) Try adjusting it
4) Talk to the guy simple, also that adjusting nut on top of the bov, doesn't look like the one Greddy supplies, maybe he lost it and replaced it with somethign else that isn't allowing you to adust it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Just to clarify, the HKS SSQ should flutter in vacuum and sometimes at low boost, correct?
Mine flutters in those circumstances, and as I understand it thats normal. If I give it good throttle it chirps.</TD></TR></TABLE>
Nick, My roomate had the Hks and I noticed It did the same thing, in partial throttle/vacuum it would flutter.
Old Apr 24, 2004 | 09:56 AM
i'll check into that . . . thanks guys. I don't want to blast anyone, just talked to SIMPLE . . . he's a good guy. he said his friend had it tightened down for 18psi which is maybe my 7psi can't open the BOV?
I'll cut some slack and check on the vacuum source. I had everything ran the same before and it all worked, but I will double check
Old Apr 24, 2004 | 05:27 PM
scatuli's Avatar
that and make sure it isn't hooked up to a secondary source vacuum. thats what i had mine and it wouldn't open the bov unless i was full throttle. i also think your vacuum line looks very sketchy ie. very thin, make sure it isn't collapsing and it is excessively long.
Old Apr 24, 2004 | 09:54 PM
Cool, thanks for the clarification Iggy
Old Apr 24, 2004 | 10:22 PM
-iLLuZioN-B18C1's Avatar
i have the same fluttering. but mines from my filter for some reason. if i run no filter, itll sound fine, then throw on the filter, it flutters. andyone else have this problem or know how to make it go away?
Old Apr 25, 2004 | 11:51 AM
Default Re: Fluttering BOV (scatuli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">that and make sure it isn't hooked up to a secondary source vacuum. thats what i had mine and it wouldn't open the bov unless i was full throttle. i also think your vacuum line looks very sketchy ie. very thin, make sure it isn't collapsing and it is excessively long.</TD></TR></TABLE>
i'll check into that I se tht ebov to as loose as I could and that helped out a lot! I got it to whistle with a slight flutter behind it. I even tried spraying some lubricant into the horn part of the bov to free up any parts that may be sticking. I guess I need to either check the bov line (perhaps get a bigger line) or try a different vacuum source. I had things hooked up the same way on my last setup and everything worked fine, but my last setup I had:
an internal gate rather then an external gate so maybe the external gate is taking up most of the vacuum or something?
Old Apr 25, 2004 | 07:39 PM
bump
tallyturbo
Jan 21, 2006 11:13 AM
boostin1cam
Aug 20, 2005 07:31 PM
a1320addict
Apr 29, 2005 06:01 PM
bluels-t
Sep 27, 2004 01:45 PM
reefer_bob
Jan 8, 2002 02:54 PM
