Flat top vs Dish pistons
Old Jul 2, 2004 | 02:51 PM
Bspec18's Avatar
Default Flat top vs Dish pistons
Given the same compression. Which would you prefer ? I went with dish because of the valve reliefs, but i'm having second doubts if i made the right choice. The are ROSS pistons btw
Old Jul 2, 2004 | 02:54 PM
MachAF's Avatar
Default Re: Flat top vs Dish pistons (Bspec18)
Ross pistons are nice.
you'll enjoy them.
Old Jul 2, 2004 | 03:08 PM
shadow103rd's Avatar
Bump........Id like to know also. Pros and Cons of Dish and Flat Top piston???
Jon
Old Jul 2, 2004 | 03:14 PM
Chip's Avatar
Default Re: Flat top vs Dish pistons (shadow103rd)
I don't understand what you're saying, there isn't any way to get the same compression with both a dish and a flat top piston on the same motor. Dished means you have an actual dish or reverse dome which creates a lower CR. Flattop means the only "dish" to the piston is the valve releifs, which gives you higher compression than a dished piston.
Old Jul 2, 2004 | 03:29 PM
Rtype16's Avatar
Default Re: Flat top vs Dish pistons (Chip)
I was scratching my head thinking the same thing.
Old Jul 2, 2004 | 04:18 PM
TrueNorthStar's Avatar
Default Re: Flat top vs Dish pistons (Rtype16)
You can get the same compression with both pistons if you increase the piston to deck height. I'm not sure if that is such a good idea though.
Old Aug 17, 2004 | 04:39 AM
GOLDBERG's Avatar
Default Re: Flat top vs Dish pistons (TrueNorthStar)
are there any problems with carbon buildup on dish pistons? and bump for pros and cons of each
Old Aug 17, 2004 | 05:00 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote"> I went with dish because of the valve reliefs, but i'm having second doubts if i made the right choice.</TD></TR></TABLE> The deepth of the valve reliefs should have nothing to do with whether you are running a dome, flat or dished piston. They are based off the height of the piston (at the very edge). You can have deeper reliefs on a 13-1 piston than an 8-1 piston.
Old Oct 4, 2005 | 02:09 PM
murtnabila's Avatar
Default Re: Flat top vs Dish pistons (earl)
what do most people prefer for a 500+hp setup?
Old Oct 4, 2005 | 02:17 PM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">I don't understand what you're saying, there isn't any way to get the same compression with both a dish and a flat top piston on the same motor. Dished means you have an actual dish or reverse dome which creates a lower CR. Flattop means the only "dish" to the piston is the valve releifs, which gives you higher compression than a dished piston.</TD></TR></TABLE>
Yes you can... get the valve reliefs cut larger and deeper and you will end up with a flat top piston with the same compression ratio as a slightly dished piston with smaller and shallow reliefs.
Old Oct 4, 2005 | 03:11 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Flat top vs Dish pistons (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you can... get the valve reliefs cut larger and deeper and you will end up with a flat top piston with the same compression ratio as a slightly dished piston with smaller and shallow reliefs.</TD></TR></TABLE>
on that note..then the flat top would seem better as far a quench is concerned..(IMO)
Ryan#1
Oct 2, 2008 06:27 PM
ochsy03
Mar 12, 2005 08:33 PM
totalimpact
Dec 9, 2003 03:48 PM
Mark
Aug 26, 2003 09:36 PM
greengangsta
Mar 18, 2002 07:23 PM
