JE PISTONS
Old Mar 18, 2002 | 07:03 PM
greengangsta's Avatar
Default JE PISTONS
i found a set of je pistons and crower rods (used). how do you tell if a piston is high comp. or low comp? also how can you tell the compression ratio of the pistons? i looked inside the one of them i saw 87 engraved inside the piston. what does that mean?
Old Mar 18, 2002 | 07:23 PM
boosted hybrid's Avatar
Default Re: JE PISTONS (greengangsta)
It is either a dome shape or dished shape. The dome shaped pistons are higher compression, while the dished style are lower compression. The 87 that you see stamped into the bottom of the piston is not the bore of the piston. I have a set of 84mm brand new, they have 83 stamped on the bottom of them. You need to take measurements of the piston, call JE and ask a tech rep he can tell you what compression the piston is in relation to your block and head type.
tban21
Jun 26, 2012 04:56 AM
fjt
Jun 9, 2010 06:18 AM
Bspec18
Oct 4, 2005 03:11 PM
high_revs
Jun 17, 2005 09:40 AM
Mark
Aug 26, 2003 09:36 PM
