Finally done!..almost
Old Feb 18, 2002 | 09:11 PM
Darin D.'s Avatar
Default Finally done!..almost
I finally got everything together and working correctly....unfortunately i was given the wrong hondata box, the n/a one. So when i went out and tried boosting for the first time it hit fuel cut!
I also found out that the bosch injectors I was sold were not saturated injectors and they need the resistor box...found one in a matter of 3 hours and installed it, so everything is good and I should be boosting by tomorrow when i get the correct hondata box.
here is the bosch 550cc injector. fits nicely with minor modification.
Also, does anyone know how much boost would be safe running with the stock fuel pump at 43 psi and 550cc injectors. I've been told that I should be fine at low boost levels under 10 psi. I have the bosch fuel pump but I haven't installed it yet.
Old Feb 18, 2002 | 09:25 PM
VaporTrail's Avatar
New User
Default Re: Finally done!..almost (Willis)
What did you have to do to make the Bosch injectors fit? Drill out the bosses?
Old Feb 18, 2002 | 09:30 PM
paulzy's Avatar
Default Re: Finally done!..almost (VaporTrail)
nice.....good luck with the hondata issue
Old Feb 18, 2002 | 09:31 PM
Darin D.'s Avatar
no..I didn't have to modify the rail at all. I shaved off some plastic on the area below where the o ring sits on the top of the injector.. basically i just kept shaving off material until it slid into the rail far enough to seal. I also had to space the fuel rail away from the manifold using 12mm nuts..they turned out to be the perfect size. I'm using the stock o rings.
if you look at the injector in the pic you can see where i shaved some of the plastic.
[Modified by Willis, 6:33 AM 2/19/2002]
Old Feb 18, 2002 | 09:54 PM
Adi Radoncic's Avatar
On Fire!
Hey looks like you got yourself a pritty nice setup, can youlist what you got there for turbo i/c etc....
Thanks,
Adi
97dc2
May 30, 2005 10:30 PM
chihuahuamanx
Jan 13, 2005 11:02 PM
RedZone
Oct 2, 2004 08:59 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
smoothludey2
Oct 1, 2001 03:27 PM
