it feels like fuel cut but its not
* B A N N E D *
i have a b16a with 1.5mm gasket greddy kit w/intercooler 31v, fmu 12:1, 255lbs fuel pump and 310cc injectors, my problem is at 6lbs of boost as soon as i hit vtec my car feels like it hit a brick wall it just spudders. i have no idea what it is i wouldnt think that i would be leaning out on fuel, it pretty much only does it at vtec. i dont have a missing link or anything at the time im using check valves, someone tried to tell me that it was doing it cause my map was reading boost, but if it was i would think that it would throw a code or something, its not. any suggestions
* B A N N E D *
Re: it feels like fuel cut but its not (VaporTrail)
if it is too much fuel then why does it do at vtec only, out of about 6 times getting on it atleast 5 of them were as soon as i hit vtec, i put the vtec at 7000 and it was clean all the way to 7000 then it did it again, and also if its too much then would i be able to run without the fmu, and could i fix the prob with a v afc cause i do have one that i didnt mention
