Vortech FMU ratio???
Old Oct 10, 2001 | 08:52 PM
therealnapster's Avatar
New User
Default Vortech FMU ratio???
I'm running a 95' bottem end (d16z6), 97' sohc vtec head (d16y8). GReddy kit, bov and 2mm head gasket, front mount, AEM rail, SX reg. Waloboro "FI" pump, Apexi SAFC and AVCD, stock injectors, and the Vortech FMU that comes with the kit. It is calabrated to 12:1 (fuel press:lbs. of boost) this ratio is intended for use with a stock fuel system, since I have the pump, rail, and regulator (@40psi static) plus the fuel and boost controller I should be able to safely lower my fuel pressure under boost by recalabrating my FMU. Recalabration kits come for ratios of 10:1, 8:1, or 6:1. I want to run 8psi @ the track and 5.5-6 and street. Any sugestions as to which ratio would be best?
12:1= 112lbs. fuel press, @6psi/136lbs. fuel press, @8psi
10:1= 100lbs. fuel press, @6psi/120lbs. fuel press, @8psi
8:1= 88lbs. fuel press, @6psi/104lbs. fuel press, @8psi
6:1= 76lbs. fuel press, @6psi/ 88lbs. fuel press, @8psi
Let me know what you think.
-Derek-
[Modified by sohckid, 5:55 AM 10/11/2001]
Old Oct 10, 2001 | 09:47 PM
Giuseppe's Avatar
Default Re: Vortech FMU ratio??? (sohckid)
i dont know much but from what i've read on this board:
with STOCK injectors, the 12:1 is the way to go...
would someone please comfirm..
Old Oct 10, 2001 | 11:54 PM
Sonny's Avatar
You shouldn't recalibrate the FMU unless you change the size of your injectors. For example, if your stockers are 240cc min (they are) and you go up to 310cc injectors, you've increase the size by roughly 20%. So, the rise rate of the FMU needs to go down by the same amount. If you had a 10:1 disk before, you'd now need an 8:1.
Sonny
Old Oct 11, 2001 | 07:06 AM
VTC_CiViC's Avatar
Default Re: Vortech FMU ratio??? (Giuseppe)
If you stick with the stock injectors you'll defintley need a 12:1, but you'll also need a high pressure inline pump and you'll stil be ultimatley limited to like 8-9psi before you murder an injector with that kind of pressure. Even at 100psi, my stocks are running close to 70% duty cycle, 80% is max for the stocks I belive so you'll be cutting it kinda close from what I gather... maybe somebody else can give us a clearer picture though as to how much pressure a stock 240cc injector can handle..?
huge230
Mar 3, 2007 01:53 PM
Ultra Jurassic
Jun 22, 2005 07:54 AM
wpgcivic
Jul 7, 2004 05:45 AM
nigel
Jul 11, 2003 08:57 PM
RNPoo7
May 7, 2003 03:24 PM
