Expected Hp!
Old Apr 21, 2004 | 09:43 PM
done's Avatar
Default Expected Hp!
I have no clue what to expect out of my kit.
Full race kit + t3/67 on stock b18c5 @ 8 psi.
Ill be happy with over 300whp .
What you guys think?
BTW: april 29th is the starting day
Old Apr 22, 2004 | 06:02 AM
done's Avatar
Default Re: Expected Hp! (Jordo)
go up
Old Apr 22, 2004 | 06:25 AM
00siBuilder's Avatar
stock type R? Got no ideas for numbers never put anything together like that.
Free bump though.
Old Apr 22, 2004 | 06:38 AM
TrueNorthStar's Avatar
Default Re: Expected Hp! (00siBuilder)
Is this like guessing how many jelly beans are in a jar? What do we win?
I'll say...... 313@8psi
heheh
Old Apr 22, 2004 | 06:39 AM
0x64Work's Avatar
I wish I could of made it I will talk to you when I get home. My guess is 300whp.
Old Apr 22, 2004 | 06:45 AM
PrecisionH23a's Avatar
A buddy of mine put out 250whp on a b18c5 with a fully done JG head, drag gen 2 turbo, crane ignition, and v-afc at 5psi. I believe the turbo had a 57 trim comp and a .48 t3 a/r.
I would say due to the larger sized turbo, a nice ems, and full-race kit at 8psi you should see anywhere from 275-300whp depending on how conservative you keep your tuning.
Old Apr 22, 2004 | 06:58 AM
done's Avatar
Default Re: Expected Hp! (PrecisionH23a)
i have aem ems with some nice 1000cc injectors, tony1 is tuning
Old Apr 22, 2004 | 07:00 AM
I'd say you should be able to hit 300whp in that case then. How come you are running 1000's? Plan on a built motor soon?
Old Apr 22, 2004 | 07:08 AM
done's Avatar
yup
Old Apr 22, 2004 | 07:09 AM
chirp3rd's Avatar
i think you will just make with very good tuning
Old Apr 22, 2004 | 07:14 AM
Just curious, are you running an adj fpr?
Old Apr 22, 2004 | 07:31 AM
done's Avatar
yes aem
Old Apr 22, 2004 | 07:42 AM
93LSivic's Avatar
I would say easily 300 whp. With that turbo and the C5 compression and Tony tuning, hell ya
Griffin@Camtech's Avatar
563.78456 HP at the wheels
they make this little thing called a dyno. u should try it
Old Apr 22, 2004 | 07:47 AM
Default Re: Expected Hp! (Stickdeath)
Griffin, get back to work secretary bitch.
Old Apr 22, 2004 | 07:50 AM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath &raquo;</TD></TR><TR><TD CLASS="quote">563.78456 HP at the wheels
they make this little thing called a dyno. u should try it</TD></TR></TABLE>
i know *******, im thinking what to expect on the dyno
Old Apr 22, 2004 | 07:54 AM
Tony1 is doing the tuning......
I have a feeling you are not going to stop at 8psi
You will prolly end up at 10-12psi
Old Apr 22, 2004 | 08:20 AM
alpha's Avatar
Don't try and push it too much Jordo.
Old Apr 22, 2004 | 08:25 AM
hulkhb's Avatar
Default Re: Expected Hp! (0x64)
None the less be nice to see another stock c5 plot before i dyno mine. Good luck
Old Apr 22, 2004 | 08:34 AM
PM-Performance's Avatar
Default Re: Expected Hp! (hulkhb)
you all might think im nuts, but im guessing closer to 350ish whp. between the size of that turbo and Tony tuning it . i can easily see that happening.
**** i made 300whp on my 1st set up at 8psi . your turbo is alot bigger. and we stayed real conservative with the tune.
Old Apr 22, 2004 | 08:55 AM
m R g S r's Avatar
Default Re: Expected Hp! (itr206)
I don't think that you could push 12psi on a stock b18c5...
Old Apr 22, 2004 | 08:58 AM
yes master back to work it is
Old Apr 22, 2004 | 09:00 AM
Default Re: Expected Hp! (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that you could push 12psi on a stock b18c5...</TD></TR></TABLE>
Would you put money on that? i have done it for a little on mine before i took it out to build it . i didnt care if it broke though. if i wanted it to last i wouldnt have done it . lol
Old Apr 22, 2004 | 09:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you all might think im nuts, but im guessing closer to 350ish whp. between the size of that turbo and Tony tuning it . i can easily see that happening.
That does sound a bit high, but then again he is running some nice trims.
a stock block b18c put out 330whp at 8psi on a sc63 here (https://honda-tech.com/zerothread?id=678388), so 350 may not be that crazy to believe... that will take some damn good tuning though with a decent amount of timing.
But either way, I always try to underestimate my guesses... that way when they hit more they are happy instead of hitting less and being dissapointed
Old Apr 22, 2004 | 09:03 AM
m R g S r's Avatar
No, I won't put money on it, but I blew my b18c1 @ 11psi. I'm sure it would work, just not last very long.
