Expected Hp!
Old Apr 22, 2004 | 12:56 PM
  #51
TrueNorthStar's Avatar
Default Re: Expected Hp! (vtec.dc2)
I think he wants like 500+hp when he gets a built block.
Old Apr 22, 2004 | 12:59 PM
  #52
done's Avatar
Default Re: Expected Hp! (TrueNorthStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">I think he wants like 500+hp when he gets a built block.</TD></TR></TABLE>
ypu 500whp is goal
Old Apr 22, 2004 | 08:45 PM
  #53
done's Avatar
Default Re: Expected Hp! (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
It blew because of power, not because of 11 psi.
Boost Pressure is Irrelavent, power kills motors.
mike</TD></TR></TABLE>
To my understanding HEAT Kills motors.
Old Apr 22, 2004 | 09:04 PM
  #54
MikeMAN's Avatar
Default Re: Expected Hp! (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
To my understanding HEAT Kills motors. </TD></TR></TABLE>
in his case, yup
mike
Old Apr 22, 2004 | 11:49 PM
  #55
boosted15's Avatar
Default Re: Expected Hp! (SiRkid)
you guys could probably make that much hp. Probably within the 200-250 hp depending on tuning. But with a B18 C5 stock, you'll be lucky if it lasts. Compression ratio would be too high, 11.5 I believe. I suggest lowering the comp. ratio a little bit, just to be on the safe side.
Old Apr 23, 2004 | 12:21 AM
  #56
swlabhot's Avatar
Default Re: Expected Hp! (boosted15)
Compression is 10.6 for USDM ITR not 11.5. I've been running on 11.1 for the past year and have done 3 full track days with it @ 10psi using band-aid pos management and its still lasting.....
I reckon over 300whp fo sure at 8psi with that turbo and mani
Old Apr 23, 2004 | 04:44 AM
  #57
Griffin@Camtech's Avatar
Default Re: Expected Hp! (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Compression is 10.6 for USDM ITR not 11.5. I've been running on 11.1 for the past year and have done 3 full track days with it @ 10psi using band-aid pos management and its still lasting.....
I reckon over 300whp fo sure at 8psi with that turbo and mani </TD></TR></TABLE>
hmmm actualy its 11.1 compression factory but who is counting right?
BTW my guess on the hp is 300 to 325
Old Apr 23, 2004 | 05:22 AM
  #58
BoostedsiR's Avatar
you will be in the mid to low 300 whp
Old Apr 23, 2004 | 06:01 AM
  #59
94gsr4dr's Avatar
Default Re: Expected Hp! (Stickdeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath &raquo;</TD></TR><TR><TD CLASS="quote">
BTW my guess on the hp is 300 to 325</TD></TR></TABLE>
Actually it's 10:6 but whos counting
Old Apr 23, 2004 | 06:18 AM
  #60
quikB18B's Avatar
Default Re: Expected Hp! (94gsr4dr)
I agree with Itr206
I think well all be suprised to see the results, I mean the average, and many Itr's Ive seen on the board are making around 290-305 on 6-7 psi tuned, so with Jordo's bigger turbo, FullRace Kit, 8 psi, and Tony on the labtop, I think well be seeing around 330/235.
Jordo if you make your goals, or a satisfying # on less boost are you going to stop, or are you going to tune for sure to 8 psi. I guess Tony will have some input as well on the dyno.
Old Apr 23, 2004 | 07:08 AM
  #61
done's Avatar
Default Re: Expected Hp! (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">I agree with Itr206
Jordo if you make your goals, or a satisfying # on less boost are you going to stop, or are you going to tune for sure to 8 psi. I guess Tony will have some input as well on the dyno. </TD></TR></TABLE>
yes, mainly what tony thinks is what is gonna happen , i just knwo its gonna be fast
Old Apr 23, 2004 | 07:54 AM
  #62
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">
Actually it's 10:6 but whos counting</TD></TR></TABLE>
B18C5 195hp@8000 130tq@7500 10.2:1 Compression 81 bore 87.2 stroke per Acura for the 1998-2001 Integra Type R
guess no one is counting
Old Apr 23, 2004 | 07:58 AM
  #63
done's Avatar
guess no one is counting </TD></TR></TABLE>
no no its 10.6:1
jdm and ukdm have 11.1:1
Old Apr 23, 2004 | 08:22 AM
  #64
once again I have been proven a dumb ***. Me and the Acura tech that wrote the FACTORY service manual. both dumb!!
long live honda tech and all its brilliant users. apparently I am not one
Old Apr 23, 2004 | 08:31 AM
  #65
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath &raquo;</TD></TR><TR><TD CLASS="quote">once again I have been proven a dumb ***. Me and the Acura tech that wrote the FACTORY service manual. both dumb!!
long live honda tech and all its brilliant users. apparently I am not one </TD></TR></TABLE>
it is 10.6:1 i **** you not
Old Apr 23, 2004 | 08:33 AM
  #66
TurboJesse
Guest
Posts: n/a
admitting your problems is the first step to recovery Since you first stated it was 11:1, then used a quote from some unknown source saying 10:2:1 i really hope your post is true instead of sarcasm...
Old Apr 23, 2004 | 01:27 PM
  #67
alpha's Avatar
We can all guess these high hp numbers on his stock bottom end but it's going to come down to how far Jordo and Tony1 want to push it. Jordo has to make the drive back to his state too.
Old Apr 23, 2004 | 02:10 PM
  #68
01ITR#700's Avatar
Default Re: Expected Hp! (0x64)
My official guess: 330whp
I made 280whp with the good old FMU setup, a turbonetics 60-1 HIFI and no tuning at all at 7.5psi on my bone stock ITR motor.
Mark
Old Apr 23, 2004 | 02:40 PM
  #69
68'superchargedLT1camaro's Avatar
The B18c5 is rated at 195 horse power at the crankshaft. Regardless of turbo charger size, if this kit is set up to produce 8 pounds of boost at redline, with a properly sized intercooler, and correct tuning this should produce around 290 horse power at the crankshaft. Front wheel power numbers will be even less due to drive train losses. This is a "ball park" figure, as their are many variables to be considered, but this is guaranteed to be closer than any others previosly posted.
Old Apr 23, 2004 | 02:44 PM
  #70
alpha's Avatar
Default Re: (68'superchargedLT1camaro)
I will make a friendly internet bet he will put down at least 290 wheel horsepower and he will hold 8lbs from 4900RPM to 9100RPM
Old Apr 23, 2004 | 03:12 PM
  #71
If this B18c5 is bone stock, with the only modification being a turbo kit that produces 8 pound of boost, I'm sticking to 290 at the crank.
Old May 13, 2004 | 06:51 PM
  #72
markaria's Avatar
My educated guess would be 250-260 whp at 8 psi if only reving to 8200 or so on a mustang type dyno, closer to 275 on a dynojet, and 600hp if the car is yellow...ha ha
Seriously though, the turbo's size and fuel management/tuning will have huge affects on the actual #'s
Old May 13, 2004 | 08:21 PM
  #73
tony1's Avatar
Default Re: (markaria)
My guess is around 225whp or so...
Old May 13, 2004 | 08:36 PM
  #74
Mase's Avatar
Default Re: (tony1)
everyones taking out bets for whp, who's taking out bets to see if tony can even get the aem to run
hehe j/k
Old May 13, 2004 | 08:39 PM
  #75
st00pid's Avatar
Default Re: (Mase)
My money is on..
Jordo leaves LA with AEM and returns with M4.
