est. hp at these boost ranges
Old May 21, 2004 | 01:55 PM
  #26
1316130057's Avatar
Default Re: (tyrone27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 &raquo;</TD></TR><TR><TD CLASS="quote">and why is it waste of time.</TD></TR></TABLE>
Here's why. I made the actual illustration on the compressor map you've provided with your stats. It's a little rough, but here goes:
Okay...the blue X is a range you should be between. The red X is where you would be with those stats. To get closer to the blue x's location, you'll need to run more boost, and revving higher certainly wouldn't hurt either. If you utilized this turbo in the situation you mentioned, you make power, but certainly not much. BTW, here's the numbers I used:
7200 RPM (which you provided)
108cid (which is what that scirocco measures)
I estimated an 80% V.E. which I'm sure anyone will say was more than fair.
I assumed 77% compressor efficiency.
26in/Hg as a barometric pressure, which is about average at sea level
70* day
I assumed a 2psi pressure drop across the intercooler system so 7psi outlet pressure
5psi manifold pressure
Your set up actually flows ~187CFM and your outlet temps are ~173*F.
Your sealevel corrected suction flow was 44.2 and your pressure ratio is 1.62 . To make this work...long story short, turn the boost up or rev it higher, or both. The green X is where you'd be at 18psig and your current 7200rpm limit which is about perfect for this turbo. Good luck. oohhh, before I forget, that's ~155hp assuming that it takes only 1.2cfm to make 1 hp which is considerably good. At 18psig you'd be making ~193 more hp.
Old May 21, 2004 | 03:12 PM
  #27
boosted_dc2's Avatar
Default Re: (1316130057)
thats the first time ive seen a honda-tech member actually use and display a comp. map
ive never known how to read one thouroughly, nor how to figure **** out. thats sweet.
Landon
Old May 21, 2004 | 03:23 PM
  #28
tyrone27's Avatar
Default Re: (boosted_dc2)
damn dude. never seen anyone in my life display a map like that. damn. I'm hoping to get teh crx in two weeks and buy the turbo equipment off ebay. i'm going ot put my old t3 60 trim ford t-bird turbo on it at 15psi. I know with tec 2 it should be able to take it. I was told today that I should do a motor swap to a b series motor but I always been a beliver of build whats in the car.
Old May 21, 2004 | 10:07 PM
  #29
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">thats the first time ive seen a honda-tech member actually use and display a comp. map </TD></TR></TABLE>
Wow. That, my friend, is dissapointing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">ive never known how to read one thouroughly, nor how to figure **** out. thats sweet.
Landon</TD></TR></TABLE>
I was going to offer to show you, but then I remembered that there are 2-3 threads already on how to read comp. maps. I just glazed over them, but they seemes to hit all the important ****.
[quote]I'm hoping to get teh crx in two weeks and buy the turbo equipment off ebay. i'm going ot put my old t3 60 trim ford t-bird turbo on it at 15psi.[/quote
Did you rebuild it yet? If not, have fun with the smoke screen.
Old May 22, 2004 | 03:41 AM
  #30
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">
70* day
I just checked these numbers, and they look close enough.
I got a little more airflow, and a little more power (well, were you talking about WHP or CHP?)
assuming 10% drivetrain losses, you're talking in the 150 whp range at 7000 rpm, assuming 80% VE. I think it's likely that your VE is lower than that at 7k though, on an older CRX.
With 7 psi turbo outlet pressure, I don't think he will see a full 2 psi drop through the intercooler. Probably more like 1 psi.
I also got more like 190 CFM.
Regardless, both of us are telling the same story.
Old May 22, 2004 | 10:35 AM
  #31
1316130057's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless, both of us are telling the same story.</TD></TR></TABLE>
I was using CHP. Anyone's numbers will be different depending on what conversion they use from lbs/min to CFM and how much CFM they decide it takes to make 1hp. I used the 80% V.E. to try to tilt the numbers a bit in his favor. It's probably off by no more than 5%. And with such low boost and the amount of piping it'll take and a Starion IC on top of all that, he'd definitely see a 2psi drop, 1 from the IC and another from the decompression that's going to happen in the piping.
But, at the end of the day, you're right. We are telling the same story. The differences would be slim to none.
Old May 22, 2004 | 10:43 PM
  #32
kpt4321's Avatar
I disagree. I don't quite see 2 psi of pressure drop, at 18 psi through a DSM SMIC (smaller core than a starion) and probably about the same amount of IC piping.
Still, pressure drop doesn't make a huge difference.
Old May 22, 2004 | 10:58 PM
  #33
1316130057's Avatar
Still, pressure drop doesn't make a huge difference.</TD></TR></TABLE>
I dunno. I still see at least a 1psi drop across the piping and another 1 after the IC is done diffusing the charge. Unless the piping were 2" or smaller.
thermostate82
Jan 1, 2009 10:46 PM
trex352
Jun 6, 2007 09:04 PM
Sci_v_icI
Mar 29, 2006 01:18 PM
Sam1am26
Nov 26, 2004 06:51 PM
mrx
May 12, 2004 11:20 AM
