Something doesn't look right with this drain line
Old Jul 15, 2007 | 07:16 PM
greasemonkee's Avatar
Default Something doesn't look right with this drain line
The fittings are Russells -10, the hose is -10. Why are the backs of the hose ends so big to leave such a gap? They went together tight.
Old Jul 15, 2007 | 07:19 PM
Chris Tune's Avatar
Default Re: Something doesn't look right with this drain line (greasemonkee)
wow... sorry but wow... thats the most cute worst installed drain line i have ever seen...
seems like whoever did this have never seen a how-to make drain lines... whatever happened to two 45's and a straight shot almost to the pan...
looks like the drain line was soldered to the oil pan before they even put the turbo on the engine
Old Jul 15, 2007 | 07:33 PM
lovey408's Avatar
Default Re: Something doesn't look right with this drain line (Chris Tune)
off topic a little but i need a oil return line too becuz the one i have now is out of rubber.. where do i get the steel braided one like yours???
Old Jul 15, 2007 | 07:47 PM
Default Re: Something doesn't look right with this drain line (lovey408)
The pan is a Moroso with the bung pre-installed. The Manifold is an Inline pro and the drain outlet on the turbo is nearly level to the bung on the pan. I looked at this for an hour solid trying to figure a better combination. Another 45 will only make it worse. They're pretty close together to begin with.
Thanks for the compliment. I know I suck, but I don't have a warehouse of fittings in the shop here.
Old Jul 15, 2007 | 07:57 PM
rainmanEK's Avatar
big strong guy
I would not even run that 45 off of the turbo. Try just getting a straight barb fitting for the turbo and the oil pan and just clamping the braided line on.
Try to keep it simple!
Eric
Old Jul 15, 2007 | 08:00 PM
Chris Tune's Avatar
bleh sorry didnt realized it was a morosso oil pan ... i would have relocated the entry one on the pan and centered it with the one in the turbo... but now u can use a lil shorter hose... that one is angled upwards just before the pan... it will not flow oil correctly
Old Jul 15, 2007 | 08:11 PM
Muckman's Avatar
Moderator in Chief
Can you post a picture of the fittings coming off the CHRA?
Old Jul 15, 2007 | 08:16 PM
I B BANGGIN's Avatar
the line looks like its a -8an line and not the -10an....i would recheck that!
Old Jul 15, 2007 | 08:22 PM
Default Re: Something doesn't look right with this drain line (Muckman)
Old Jul 15, 2007 | 08:39 PM
BlackBeastEK's Avatar
thats simple you have -10an fittings with a -8an braided line thats it
Old Jul 15, 2007 | 08:46 PM
Muckman's Avatar
Moderator in Chief
Thats what I thought. You have that the drain fitting (female) with a male to male coupler then your 45* fitting. They make <u>male</u> drain fittings that would eliminate the coupler and would raise the whole line half an inch or more.
Like this from ATP
Old Jul 15, 2007 | 11:07 PM
Yep I just measured it, I wouldn't have thought they sent me -8 line when I ordered -10
Old Jul 16, 2007 | 12:01 AM
lovey408's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee &raquo;</TD></TR><TR><TD CLASS="quote">Yep I just measured it, I wouldn't have thought they sent me -8 line when I ordered -10
can i ask where u ordered this from?
Old Jul 16, 2007 | 04:59 AM
Topdawgg's Avatar
yup, definetly a -8 line... they are suppose to fit snug inside the fitting
Old Jul 16, 2007 | 05:39 AM
TDautowerkes's Avatar
that line is -8 send us your address ill send u 1 foot of -10 for free + shipping!
Old Jul 16, 2007 | 05:46 AM
I.C.C.'s Avatar
Default Re: Something doesn't look right with this drain line (TDautowerkes)
damn hows that for customer service!!!
Old Jul 16, 2007 | 07:15 AM
akira712's Avatar
you a aircraft or motorbike mech?
Old Jul 16, 2007 | 07:41 AM
93supercoupe's Avatar
Default Re: Something doesn't look right with this drain line (akira712)
THATS MY MOTOR!!!
j/k, just get the male fiutting and the right size line and be done with it.
It seems of u twist that 45, it will be a straight shot to the pan.
Old Jul 16, 2007 | 08:26 AM
Default Re: Something doesn't look right with this drain line (93supercoupe)
Here's the scoop. I sat down and carefully measured the line again to confirm what size it was. The line really is infact a -10 since I measured a round end (not one freshly cut) this time and it measured 5/8" which is 10/16 (or -10). The problem is that those are Russell full flow type hose ends and they require Russel pro flex type hose. I am using a thinner walled teflon hose.
Moral of the story: don't mix hose and hose ends that aren't compatible with each other even if they are the same manufacturer.
Thanks for the hose offer, and I went to aviation maintenance school however you can tell.
Old Jul 16, 2007 | 08:31 AM
ok we can send you hose ends foir ss type hose....
those are NOT free....lol
Old Jul 16, 2007 | 08:46 AM
turboteg2nv's Avatar
and I went to aviation maintenance school however you can tell. </TD></TR></TABLE>
I think locking the bolts on the return line with wire is a good indication
Old Jul 16, 2007 | 09:34 AM
meanEG's Avatar
Default Re: Something doesn't look right with this drain line (turboteg2nv)
i would really try to change the set-up. i wouldnt want toil sittinmg in the line like that. that might back up up to the turbo too.
Old Jul 16, 2007 | 11:34 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">
I think locking the bolts on the return line with wire is a good indication </TD></TR></TABLE>
haha just maybe. That's nicely done too.
Old Jul 16, 2007 | 02:40 PM
TunerToys's Avatar
We manufacture an AN style drainflange as well. Althought the drain flange you currently are using is a fine looking piece , we'll send you one of these for free to help out the slope of your drain line. Should raise it about an inch on the turbo end.
They are available here - AN Drain Flange for T3/T4 at Tuner Toys
Hit us with a PM (from your username - greasemonkee), and we'll send it out at no cost.
You'll need to transfer over your cool safety wire hardware.
Craig
Modified by TunerToys at 12:48 AM 7/17/2007
akira712's Avatar
Default Re: Something doesn't look right with this drain line (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
haha just maybe. That's nicely done too. </TD></TR></TABLE>
How do you know? that you cant see the other end, if both sides arent twisted and terminated right lockwire is useless.
But yea thats how i knew
&lt;&lt;&lt;&lt;&lt; this guy = avionics tech
