A couple Questions about rebuilding Engine?
Old Jan 13, 2004 | 10:51 AM
VanHonda's Avatar
Default A couple Questions about rebuilding Engine?
When rebuilding my engine, what should I use to seal around the oil pump and the cover at the opposite end of the block? Would just regular RTV be fine? Also for a built engine should i replace the exhaust manifold gasket? I have seen them re-used so I'm not sure on home necesary this is. Lastly, what is a good assembly lube to use if the engine probably wont be started for a while?
Thanks,
Craig
Old Jan 13, 2004 | 10:59 AM
redboost10's Avatar
Default Re: A couple Questions about rebuilding Engine? (VanHonda)
i used rtv after i rebuilt my engine this summer because of a nos problem. im sure the hondabond stuff is "better" but rtv has worked for the past rebuilds ive did on v-8s and has worked on my honda b16 since last summer.
Old Jan 13, 2004 | 11:00 AM
VanHonda's Avatar
Default Re: A couple Questions about rebuilding Engine? (tgh99si)
Is hondabond a dealer thing or can you get it elsewhere?
redboost10's Avatar
its a dealer thing
Old Jan 13, 2004 | 11:23 AM
sporkcrx's Avatar
Instead of the official honda-bond you can just use "Permatex Ultra Grey" I believe it's the same stuff, yet cheaper
Old Jan 13, 2004 | 12:25 PM
VanHonda's Avatar
Default Re: A couple Questions about rebuilding Engine? (sporkcrx)
Any opinions on the exhaust manifold gasket?
Old Jan 13, 2004 | 01:27 PM
platinum00's Avatar
just use the stock one.
stock gaskets.
platinum.
redcivic
Dec 2, 2015 12:34 PM
TurboEK9Coupe
Aug 15, 2007 10:12 AM
4DRmafia
Jun 10, 2004 01:18 PM
michael O
10
Jul 12, 2003 08:19 AM
civcexcoupeblack
Apr 24, 2003 08:20 PM
