engine builder.....
Old Feb 7, 2008 | 02:18 PM
sikek1's Avatar
Default engine builder.....
Hey guys need a motor put together, who would you guys recommend based on experiences that you guys have gone through or know about...
Old Feb 7, 2008 | 02:21 PM
.dave's Avatar
i HAS questions ?
Default Re: engine builder..... (sikek1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikek1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys need a motor put together, who would you guys recommend based on experience...</TD></TR></TABLE>
There are plenty of reputable people on here that can build an engine for you. If you don't need it sleeved, I'd stick with someone fairly local to you in Florida. Check the tuner directory at the top of the main FI forum list for tuners in Florida; a lot of them build engines too, and if not they can point you in the right direction.
If you do want/need the block sleeved, all of the sleeving companies will also assemble the engine for you.
Old Feb 7, 2008 | 02:23 PM
sikek1's Avatar
I had my block sleeved by aebs, just really didnt know if I should send it all the way back for assembly...
Old Feb 7, 2008 | 02:27 PM
.dave's Avatar
i HAS questions ?
Default Re: (sikek1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikek1 &raquo;</TD></TR><TR><TD CLASS="quote">I had my block sleeved by aebs, just really didnt know if I should send it all the way back for assembly...</TD></TR></TABLE>
Did they hone them for pistons or not?
Either way I'd recommend going with someone local. Its not difficult work to have the block honed and assembled. You're lucky enough to be in Florida too with a good amount of people that have experience building Honda engines.
Old Feb 7, 2008 | 02:31 PM
sikek1's Avatar
all they did was basically install the sleeves... so I do need final bore and hone... I just wanted to make sure it was put together right, I have had a couple of issues in the past with half *** work done in my area...
Old Feb 7, 2008 | 03:06 PM
ctr83's Avatar
laskey racing Mike is one of the best guys in the business .
dsmslyr55
Sep 9, 2009 03:10 PM
RA217252
Apr 3, 2006 01:45 PM
jurenic
Sep 25, 2004 01:21 PM
90da4dr
Jun 15, 2004 07:43 AM
VTC_CiViC
Jan 22, 2002 04:56 PM
