eletronic boost controlers
Old 01-17-2016, 06:26 PM
96ekb20's Avatar
Default eletronic boost controlers
whats everyone running ? any good ones in the 250-300 range? i seen hdi has one but its doesn't have a sensitivity setting to keep boost steady and not drop off or spike like the GFB does. any insight would be appreciated
Old 01-17-2016, 08:42 PM
Moderator
TheShodan's Avatar
Default Re: eletronic boost controlers
You need to go here, and look at the possibilities and options. Many here like to try and use their Engine Management to help be their interface, while others like myself, use independent boost control from Sources like GReddy, HKS, Turbosmart e-Boost, and World Electronics.
I have no idea what HDI is GFB, but again, if you look at this link below and ask specific questions there over creating a thread, you'd be better off.
Old 01-18-2016, 03:57 AM
Masterl1nk's Avatar
What kind of EMS are you running? Almost all of them has EBC capabilities
Old 01-18-2016, 05:12 AM
turbohatch96y7's Avatar
I use my aem v2 to control boost
Has boost by gear
Tps
Speed
Controls over/under shoot
Gain
Etc
Works really good
Old 01-18-2016, 01:02 PM
96ekb20's Avatar
The shodan the link isnt working. i was looking at some greddys but they dont allow for boost ramp like the GFB the GFB is made in Australia and they have a great demo that goes over how there whole controller works and its comes in at a 270 price tag as to some 4-500 greddys and turbo smarts. i like the turbo smart as it fits where to boost gauge would but at that price i mite as well ditch my crome ecu and go hondata.
Old 01-18-2016, 03:25 PM
I never narc'd on nobody!
NotARaCist's Avatar
https://honda-tech.com/forced-induct...llers-3210811/
Fixed link.
Old 01-18-2016, 04:03 PM
bergercurtis's Avatar
How would "boost by gear" work on a vehicle with an analog VSS? I'm curious to how gearing is 'recognized' or detected reliably. Maybe I need to do some more research, but of all the talk I've really seen on it, no one can describe the theory- only observations. Any explanations would be appreciated.
Old 01-18-2016, 04:06 PM
NotARaCist's Avatar
It's not exactly hard to take speed and RPM, and figure out gear.
Old 01-18-2016, 04:14 PM
Maybe I'm overlooking a speed sensor on my car. Is there another vehicle speed sensor that is not the manual speedo cable? That's primarily what I'm after.
Old 01-18-2016, 04:31 PM
NotARaCist's Avatar
Well it would depend in your setup. If you're talking about your '91, then I think the VSS is in the cluster, but depending on what ECU you're using, you should be able to find a source for the VSS. Besides, VTEC needs the speed to activate (unless you're bypassing that), so there's bound to be a source you can use.
Old 01-18-2016, 05:18 PM
I think his car has a legit cable that spins for the odometer
Old 01-18-2016, 05:28 PM
It does. What about at the distributor? Is there anyway to obtain a vehicle speed there, or at the crank? I am talking OBD0 converted to OBD1..
Old 01-18-2016, 05:31 PM
NotARaCist's Avatar
The '91 does, but from what I was reading before I posted, that cable runs to an electronic sensor of some type in the cluster.
Old 01-18-2016, 05:44 PM
If I can tap into that, I'm down. I'm just curious if anyone has done it before, or used other sources.
Old 01-18-2016, 06:41 PM
yungmulacrx's Avatar
There is a wire that runs to the ecu from the cluster which would be you vss input for the ecu.. the speedometer is cable driven but there is a wire that runs to the ecu on obd0 vehicles.. it should be number b16 at the ecu yellow with red stripe if I remember correctly..
Old 01-20-2016, 10:23 PM
96ekb20's Avatar
so if i have a 7psi spring in my waste gate what psi would i want to stop turning up boost before i need to change springs?
Old 01-22-2016, 06:38 PM
2kdrift's Avatar
From what ive been reading last couple weeks it really depends on your setup...manifold design, type of boot solenoid your using etc. As long as your controller is doing its job properly your fine, Generally 2x on a 3 port and 3x on a 4 port. Some have reported 4x on the 4 ports(that would be 28 psi if your using a 7psi spring) but different people get different results so you just need to watch your boost carefully and make sure your not overboosting.
Im attempting this soon...I went with a 5.8 psi spring I think it was.... basically I want very little boost in first gear and by 4th I want 15-20 PSI but havent got quite that far in my build just yet
gsrt
12-14-2012 05:48 PM
RACEPAK
02-01-2010 04:50 PM
bigtom388
11-21-2009 12:30 PM
08-19-2002 06:50 PM
PrecisionH23a
06-09-2002 10:37 PM
Quick Reply: eletronic boost controlers
