Electronic Boost Controller
Old Nov 8, 2002 | 08:07 AM
7rrivera7's Avatar
Default Electronic Boost Controller
On H/T I was told the Deltagate sometimes spikes and I should use an EBC. I wanted the Tial but I understand it is not externally controllable like the Deltagate. If I buy the Deltagate, which EBC should I buy?
Old Nov 8, 2002 | 08:40 AM
Aeka GSR's Avatar
New User
Default Re: Electronic Boost Controller (7rrivera7)
greddy should do fine. if you have the extra cash spring for an avcr.
I dont see how an electric will help with boost spikes. somebody shead some light please?
[Modified by Aeka GSR, 9:43 AM 11/8/2002]
Old Nov 8, 2002 | 10:37 AM
TypeC's Avatar
Default Re: Electronic Boost Controller (Aeka GSR)
The avc-r can actually increase or decrease boost spikes in different gears, depending on how you want it to act. It is a powerful ebc.
Old Nov 8, 2002 | 11:10 AM
Honda4CX-T's Avatar
I'm also curious what to use for my TIAL to control boost.
Manual vs. Electronic, or can I ?
Old Nov 18, 2002 | 02:57 AM
mskibbz-T's Avatar
Default Re: Electronic Boost Controller (Honda4CX-R)
I read a great article awhile back comparing the popular boost controllers on the market... They put them, one at a time, on a test Eclipse and ran a few different boost settings and recorded the creep and the spool time. I was surprised at the results, some of the cheaper and simpler models performed better than the ones that cost $$$... I'll try to dig that article up, has anyone else seen it?
Old Nov 18, 2002 | 03:04 AM
GSRrR's Avatar
Default Re: Electronic Boost Controller (mskibbz)
If it is the same magazine I am thinking about, the Greddy Profec B had the lowest spike.
Old Nov 18, 2002 | 04:50 AM
Overblown-Teg's Avatar
Default Re: Electronic Boost Controller (Blade TypeC)
Blade-- do you have any idea how to set the avcr so that is will be consistent.. ours is all over the place with boost. one day 18psi and the next 21.. it changes alot with air temp and weather conditions.
Old Nov 18, 2002 | 07:39 AM
FMXer's Avatar
Default Re: Electronic Boost Controller (Overblown-Teg)
July '02 Issue of SCC
Yes the Greddy Profec B had the lowest spike.
Old Nov 18, 2002 | 08:38 AM
blufke's Avatar
Default Re: Electronic Boost Controller (FMXer)
did it review the blitz dual sbc?
Old Nov 18, 2002 | 08:56 AM
mskibbz-T's Avatar
Default Re: Electronic Boost Controller (blufke)
I checked their website and that article isn't on there... I'll try to dig it up and scan it
Old Nov 18, 2002 | 09:09 AM
racerxadam's Avatar
From all the stories I have heard about the deltagate I don't know if I would choose it over the tial. The only difference that i can see is that the deltagate can vary the spring rate with the nut and bolt on top. If you plan on using a boost controller anyway you should just get a tial with a lower pressure spring and use the boost controller to up the boost to whatever you want. Is that what you meant by externally controllable?
Old Nov 18, 2002 | 09:20 AM
coyote's Avatar
ya it did i remenber that it was well done i though anyway ...
GSRrR's Avatar
I believe so. Greddy Profec B
rustydusty1717
Jul 23, 2008 04:01 PM
GettaluvR
Nov 2, 2002 10:38 AM
SIK IN DA HED
Mar 28, 2002 07:03 AM
accordfreak
Dec 25, 2001 12:20 AM
SIK IN DA HED
Sep 13, 2001 03:16 AM
