EGT Temps (Sleeved block vs. Stock sleeves)
Hey guys I had a question. I have Darton sleeves now and the car is tuned with hondata S100b. Now my question is my EGT temps seem to be pretty high even though the car is tuned perfectly.
Is it just a characteristic of a closed deck sleeved block that the EGT temps will run hotter than stock sleeves?
I have no overheating problems, and the car runs great. I have no cat, but my 2.5" DP is very restrictive. Could this cause those temps? Thanks guys.
Re: EGT Temps (DC2R714)
i would think that egt temps would be rather cooler since maybe it was rich before. wats considered high egt temps to you, post em so the more experienced guys can give u more insight on this. good luck man.
krazy
krazy
Re: EGT Temps (krazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazy »</TD></TR><TR><TD CLASS="quote">wats considered high egt temps to you</TD></TR></TABLE>
When I am driving normally they are fine around 600C but when I am WOT they climb to 850-875C which is pretty hot. When I had a stock block and shitty tune I wouldnt peak over 800C at WOT.
Re: (ChargedLude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChargedLude97 »</TD></TR><TR><TD CLASS="quote">Are you at the same boost level you where at before?</TD></TR></TABLE>
Before with a stock motor? No if thats what you are asking. I was at .5bar on stock motor I am now at .7bar until the motor is fully broken in.
boostedcivicsir
11-26-2005 08:44 PM
spoon23_JDizM AkA SpOoN20
12-07-2004 03:43 AM
