EGT readings... 2 bar GM map sensor.. need help.. please????????!
ok.. here is what i got
precision turbo t3/t4
B16a block with JE 9:1 comp pistons and rings
EAgle H-beam rods
No SLEEVES
full head work.. port polish no new valve, but skunk2 valve springs and retain
Chipped b16a ecu with fuel map for 450cc inj.
450cc DSM inj. resistor box..
ok so heres my question...
What is the MAX temp my EGT gauge should read if it is drilled into the 1st cyl manifold like couple inches away from the block...
question #2
running the gm 2 bar map sensor off a grand nat..
can i still use a VAFC2 to fine tune my caR?? if so how??
EAgle H-beam rods
No SLEEVES
question #2
do not use the Grand national MAP it is the same as a honda one, a 2 bar, 1 bar of vacuum 1 bar of boost no need for this, and you cant use it on a factory ecu, hondata and uberdata yes,
as far as the egt goes, it is supposed to be in the 3rd runner which is the hottest cylinder you cant really tune on egts alone, you should be using a wideband as well due to false reasons for temps being high
89civic1.8T
07-12-2002 11:22 AM
