EGT Gauge ?
Old Jun 16, 2004 | 06:58 PM
playAho's Avatar
Default EGT Gauge ?
do you have to tap the EGT gauge into the manifold or can you tap it into the exhaust?
what are the prose and cons of both?
If I have to tap the manifold I will have to drill into cast. how do you tap cast?
Old Jun 16, 2004 | 11:44 PM
playAho's Avatar
Default Re: EGT Gauge ? (playAho)
TTT
some one has to know this!
Old Jun 17, 2004 | 12:03 AM
Timmay's Avatar
put it on #3 cyl pretty close to the head, i just did mine today. im not sure about cast though
Old Jun 17, 2004 | 03:54 AM
philipkrotch's Avatar
put it in the last cylinder to get fuel, it will tell you the highest egt temps because its the leanest runnning cylinder. u can put it on the DP, but in the manifold will give you more accurate readings.
Old Jun 17, 2004 | 05:45 AM
Muckman's Avatar
Moderator in Chief
The further away you put it from the optimal spot on the exhaust manifold, the colder readings your going to get. Make sense? The idea of an EGT gauge is to get an idea of what kind of temps are occuring in the combustion chamber and if your not getting accurate readings, then whats the point?
Old Jun 17, 2004 | 09:25 AM
integra-modder's Avatar
Default Re: EGT Gauge ? (Muckman)
you want in in cylinder #3 (numbers go right to left)
#3 is the hottest burning cylinder since the coolant enters at 1, is heated by cylinders 1 and 2, then three gets the already heated coolant and has less exterior surface area to dispurse its heat (such as 4 and 1 since they are on the ends).
Old Jun 18, 2004 | 03:57 PM
playAho's Avatar
Default Re: EGT Gauge ? (integra-modder)
cool thanks for the help!
Old Jun 18, 2004 | 04:33 PM
Vtec92Civic's Avatar
what about for cast iron manifolds such as the Drag Manifold . . . . still drill and tap the cast iron?
Old Jun 18, 2004 | 07:27 PM
james111's Avatar
Default Re: EGT Gauge ? (Vtec92Civic)
yes cast manifolds can be tapped, use a very good carbide at least with a lubricant while drilling...i would take it if already off car toa machinest and they will have needed bits and be able to cleanly do it.......bring along the sleeve for the probe...and make sure the probe is the best u can buy......if its a autometeg , they sell a full race probe for i believe 80 bucks or so......to go along with the standard guage......
regards
james
Old Jun 19, 2004 | 04:34 PM
playAho's Avatar
Default Re: EGT Gauge ? (james111)
how much does it cost to have a machine shop do it?
Old Jun 19, 2004 | 04:45 PM
it cost me 10 bucks to have it done.
Old Jun 19, 2004 | 05:21 PM
Frozen E's Avatar
H-T White Ops
My autometer EGT gauge instructions say to optimally tap the manifold BEFORE the turbo for the most accurate reading. You can however tap the DP after the turbo but you'll lose about 200* that way.
Old Jun 19, 2004 | 05:38 PM
Haberdasher's Avatar
Default Re: (IslandSi)
Funny how everyone has a different reason to why #3 is hottest.
I was told it was hottest because the #2 cylinder fires before the #3. That's why you often get blown head gaskets right where the two cylinder siamese together.
Old Jun 19, 2004 | 06:35 PM
Default Re: (Haberdasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haberdasher &raquo;</TD></TR><TR><TD CLASS="quote">Funny how everyone has a different reason to why #3 is hottest.
I was told it was hottest because the #2 cylinder fires before the #3. That's why you often get blown head gaskets right where the two cylinder siamese together.</TD></TR></TABLE>
This can easily be solved....
We need to find someone on here that has 4 egt probes. I remember there was a discussion about hooking 4 probes upto the AEM EMS for it to log the temps and a switchable guage....
platinum00
Dec 23, 2004 08:21 AM
Fizzader
Sep 5, 2004 09:14 AM
TurBoXBirD16
Jul 8, 2002 09:15 AM
RATEDR
Jul 3, 2002 06:34 AM
The_Head
May 5, 2002 07:14 PM
