t4 6265 questions hot side
Old 05-01-2011, 06:47 AM
punkracer's Avatar
Default t4 6265 questions hot side
in market for new housings for my t4 6265
i have a .81 ar and want boost lil sooner.. whole setup is for my t4 and 3inch band.... soo can i get .58 or.68 housings....
anyone have experance with t4 turbo witha small a/r.....
and how sooner will boost be made from a .81 ar to .58 ar..
im making 5 psi at 4100 off the spring.
Old 05-01-2011, 12:27 PM
B00st3d-dc2's Avatar
Default Re: t4 6265 questions hot side
Iirc .58 and .81 are the same thing. That is, a .58 t4 is equivalent to a .81 t3. I don't think there is a true .81 t4 housing. Seems it's just described that way for easier comparison to the more popular t3 form factor.
.58 (.81 t3 equivalent) is the smallest I've seen a t4 6265/6262 in myself.
The shodan would be the best person to answer this but that's what I've gotten from my little research.
Old 05-01-2011, 12:32 PM
Moderator
TheShodan's Avatar
Originally Posted by B00st3d-dc2
Iirc .58 and .82 are the same thing. That is, a .58 t4 is equivalent to a .82 t3. I don't think there is a true .81 t4 housing. Seems it's just described that way for easier comparison to the more popular t3 form factor.
.58 (.82 t3 equivalent) is the smallest I've seen a t4 6265/6262 in myself.
Fixed. You're about right on this. Now put the thing on and just run it. These 4-5 threads on speculation is annoying. Run and drive it this summer
Old 05-01-2011, 05:56 PM
punkracer's Avatar
does someone care to answer my question.. i didnt say anything abour T3 housing..
Old 05-01-2011, 06:41 PM
Who is Mr Robot?
wantboost's Avatar
you can't read....
a.58a/r t4 housing has the same internal volume as a .82 t3.
t4 anything is laggy on our motors.
Old 05-02-2011, 03:34 AM
Turbo-LS's Avatar
5 psi at 4100 rpm really isnt that bad, and if you were trying to build more boost it will come on quick. The more boost you run the later the wastegate opens therefore the longer AL of the exhaust gasses are going through the turbine wheel giving you quicker spool.
If you need help with anythign just call Chris and have him contact me, we can go over the setup and see what can be done before going and swapping out parts. But yeah a t4 is going to be laggy compared to a t3 but still shouldnt be that bad. i personally see 5-6psi at the same rpm with a .82 t3 hotside and not much higher rpm im seeing full 20 psi boost, it comes on really quick
Old 05-02-2011, 07:38 AM
punkracer's Avatar
awsome thanks man.. will do..
f1 vtec
01-20-2005 06:26 PM
Kp_VtekNiks
07-30-2003 12:26 PM
gsrbruin
06-25-2003 09:06 AM
kidkutz
10-06-2002 01:12 PM
Vu
01-26-2002 01:01 AM
Quick Reply: t4 6265 questions hot side
