E85 vs water meth injection?
That sucks for you. It's the users job to make sure that no forign objects get into the meth supply (causes for clogging nozzle) and as for the electric pump failing there is a VERY low chance again unless it's caused by the triggering setup.. In which case again it's user error. If a fuel pump fails and your car goes lean it destroys the engine how is that any different. Point is you need to properly install reliable parts to keep your vehicle reliable, as well as maintain them.
It might see a stupid lean AFR for a split second before all the rail pressure is gone and there isnt enough fuel being sprayed to even ignite.Its going to use whatever pressure is left in the rail and then shut off, now a pump that is getting weak is a little different, but every single one of us takes that risk.
IMO using E85 over a Meth Kit is more reliable, less aftermarket **** to fail, less worry and less variables, less wiring, less clutter etc etc.
Spray Meth it doesnt matter to me, you will find its far from popular in the Honda crowd.
Meth is fun until your pump either slows down the cycling (internal pressure regulators suck), or the pump fails, or the nozzle clogs.
K.I.S.S.
Choose a fuel, and use it.
- Derek
K.I.S.S.
- Derek
Can someone chime in on WHY methanol has better cooling properties than ETOH? Heres my stab at it. If you look at the chemical structure of both molecules, Ethanol has a higher boiling point mainly becuase it has one more carbon atom and obviously 3 more H atoms. Since the boiling point is lower for methanol, its rate of vaporization to the gaseous phase (evaporation, and as we all know evaporation is a cooling process) is faster than ethanol (ETOH) and therefore exhibits a better cooling effect.
NiceMethanol and Ethanol are very different, dont let the similarities in the name confuse you.
Methanol will make you cry if the fumes get blown in your face, Ethanol definately will not, its got a sweet smell to it.
It definately has cooling properties though (feels very cool if you pour it on your hand, similar to denatured alcohol) and supposively only burns 200deg hotter than Methanol, I know my EGT's went down vs when I was running Gas.
Depending on what ecu setup you are using, could you not set it up so if the ecu sees IAT that are high enough to know your meth kit is failing, then it backs off the boost, I am sure you could do it with the aem ems, but I am not sure about the other issues.
There's a lot of fantastic discussion of various mixtures on this page, including using NitroMethane. . .
http://www.aquamist.co.uk/phpBB2/viewforum.php?f=11
Seems like direct port might be a good idea if you were going to pump in a bunch of Nitro though! Heh heh. . .
You would be better off using an external pressure sensor or a hobb's switch if your ECU can be setup for it (AEM etc)
I'd say it depends on the availability of E85 and how much you drive. I run water/meth, which I am happy with, but the E85 gas station is 15 minutes away. I drive a fair amount, so that'd become a pain after a while.
When it comes down to it, i'd rather be running E85 than water/meth, but water/meth is much easier for me to refill.
Car is coming slowits a bare shell ATM I am just stacking parts right now, I have so much stuff still to buy it depresses me to even think about it. Still need the front end, cage, shortblock and paint before I can even start to reassemble....lol I think I went a little too far this go around but I am hoping to fall into some $$$ real soon.
With the release of the new ID2000's you better believe I will have a 4Bar map's worth of a street tune....lmfao
also the two substances release different amounts of BTUs when burned. 1 gallon of meth will release 62800 BTUs while 1 gallon of ethanol will release 84400. less BTUs released=less heat.
e85 depends if you gona daily it. i dont know how many gas stations that carry it in you area, but i would hate to have to drive all over jus to fill up
I'm lucky,the nearest station that carries it is a 3 min drive from my house,anywhere in the city or outside i'm always +/- 10-15 mins away from somewhere that has it.
Simple solution to that though,get any decent ems that can do dual maps and hook it to a switch.1 map for gas 1 map for e85.Plenty of people do that now for race gas tunes.
crazy_ace_civic
Dec 27, 2006 05:49 PM
