e-manage?
Old May 13, 2006 | 09:31 PM
EF_kid's Avatar
Default e-manage?
im looking to get an e-manage for my turbo setup i was wonderin if i buy the map sensor harness is the missing link still required.
thanks
Old May 13, 2006 | 10:45 PM
usdm ws6
Guest
Posts: n/a
Default Re: e-manage? (EF_kid)
if you get hte pressure sensor, and harness....you would use the emanage to do a "boost cut limit" and trick the stock map into reading atmospheric pressure at the most. The the emanage pressure sure is used as the map when your boosting....so you dont need a missing link
Old May 14, 2006 | 09:47 AM
EF_kid's Avatar
Default Re: e-manage? (boostedsol94)
thanks
redlseg
Apr 26, 2005 07:20 AM
civic-si-2000
Mar 3, 2005 06:07 AM
Ricey McRicerton
Oct 14, 2003 05:15 AM
Synapse
Feb 18, 2002 08:24 AM
