dyno tuning - WTF?
Old Aug 15, 2002 | 06:51 AM
wonny's Avatar
Default dyno tuning - WTF?
Everyone always says to tune your car when you go turbo, but what if you have nothing to tune it with?
I don't have an AFC, hondata or any standalone - so how do I tune? All I have is the revhard stage two, gauges and the AVCR...
I have always been confused on this...
Thanks for the help!
Dave
Old Aug 15, 2002 | 06:52 AM
Charlie Moua's Avatar
Default Re: dyno tuning - WTF? (wonny)
maybe cams and fpr.
Old Aug 15, 2002 | 06:56 AM
wonny's Avatar
Default Re: dyno tuning - WTF? (Charlie)
I have stock cams and I have am FMU, but no FPR.
sooo... no tuning for me?
Old Aug 15, 2002 | 07:25 AM
brcivic411's Avatar
you should still take it to a dyno with a Wide Band 02 to determine how your fuel setup is
Old Aug 15, 2002 | 07:32 AM
wonny's Avatar
Default Re: dyno tuning - WTF? (brcivic411)
so it is just to monitor but not to adjust?
Ok...
Spanks,
Dave
Old Aug 15, 2002 | 07:36 AM
earl's Avatar
If you can't tune it, u better learn how to rebuild it.
Old Aug 15, 2002 | 07:59 AM
dbman96's Avatar
New User
Ok...
Spanks,
Dave
Here's the deal:
you put it on the dyno and a wideband O2, this will tell you if you're running overly rich or (more likely) overly lean.
Then you have the option to either
a) Ignore the problem, start saving your $$ for the engine rebuild that will be coming your way in the near future
b) Buy whatever parts you must to correct the problem (adjustable FMU, larger fuel pump, AFC, standalone, whatever) and return to the dyno prepared to tune your car.
Old Aug 15, 2002 | 10:21 AM
DIRep972's Avatar
Smarter than you
haha i always laugh when people say that too. "get it tuned"
basically ur running the same thing i am, just a bolt on kit w/ FMU and no other devices. so there is nothing to tune really. u can adjust timing, thats it for now.
I wanted to know that my car was safe to run and in a good state of tune so i put it on the dyno w/ a wideband and got my A/F. it was safe but not optimum(10-11:1) for max power. but thats ok, as long as its safe. had it been too lean then at least i would know not to run it, and i would know that i need to change something before i run it. i guess u could say that is tuning also, i would just get it on a dyno and make sure it is "in a safe tune"
Old Aug 15, 2002 | 10:53 AM
wonny's Avatar
Default Re: dyno tuning - WTF? (DIRep972)
DIRep972,
I LOVE YOU. That is the exact thing that I was asking. I believe that kit came with a new fuel pump, right? How much boost are you running?
In any case, I'm going to get it on the dyno and see what my AF is reading at. If it needs adjusting, I'll adjust it.
THANKS AGAIN BRO.
Dave.
queens770
Engine Management and Tuning
Mar 19, 2012 12:50 PM
fastitr01
May 16, 2004 11:10 PM
BoostedD15B7
Jan 26, 2004 10:18 PM
b16ahybrid
May 20, 2003 08:23 PM
