stock head....
How much boost can a stock GSR head handle safely? I'm planning on sleeving and building my bottom end in a month or two, and I want to know if I should save for headwork of any kind before the rebuild. (yes, I did a search)
If you plan on increasing your redline, then performance valve springs and titanium retainers are a good thing to have. By porting and polishing the head youll increase the airflow into your engine, but other then that your block is usually the first thing to go byebye when boosting.
... i would suggest either cometic or inlinepro
OT : are you building you head yourself?... or are you having a shop put it together?... the reason i am asking is because i am blowing blue smoke and need my bottom end built up this winter and i was wondering if you recommended any shops in the springs?... hit me up here or on pm and lemme know... thanks...
ekhondahudson
Mar 17, 2014 03:46 PM
dunkd
Feb 27, 2005 09:12 AM
