Dual wastegate question?
Old Jun 21, 2005 | 06:24 PM
dragsol's Avatar
Default Dual wastegate question?
I run a SFP tubular manifold with the HKS standard wastegate and I am having trouble with the boost creeping from around 13 lbs. to 24 pounds by red line. I am wondering if I could make another pipe off of the Manifold and mount another HKS standard wastegate to the manifold to help getting the boost to a more manageble level for launching? I am also running a Greddy Profec B boost controller. The car will hold a steady 27 psi. thanks for the help.
Old Jun 22, 2005 | 05:07 AM
tony1's Avatar
Default Re: Dual wastegate question? (dragsol)
That should work fine. Disconnect your boost controller and run the side port of the wg to manifold pressure first, just to make sure it's not a boost controller problem.
Old Jun 22, 2005 | 05:36 AM
g2turbo's Avatar
Default Re: Dual wastegate question? (tony1)
Another option would be to buy a larger wastegate and weld on a new flange. HKS make a nice 60mm gate that would most likely do the trick. Also turbosmart makes a nice 48mm gate. What size turbo are you running?
turbo_d
Jun 5, 2022 06:46 PM
94c1v1cex
Mar 4, 2008 06:53 PM
pv2dickman
May 27, 2005 05:59 PM
pissedoffsol
Oct 19, 2003 09:37 AM
Fired Honda
Jul 18, 2003 05:42 AM
