wont build all 8 pounds
have a homemade kit that i put together with a hf manifold and a 14b turbo. when i first got the car tuned it would make all 8 pounds through all gears but first. now it builds 4 to 5 in second 5 in third and 7 in fourth. any ideas why it wont build the boost? on a full standalone tune system and the manifold and adapter plate is welded together. so it isnt a leak
Re: wont build all 8 pounds (lsvtec300)
boost controller... i can turn it all the way open and it still only builds the low boost... it isnt the controller because it worked before and the wastegate setting is 8 psi
O.G. triple O.G.
Re: wont build all 8 pounds (94c1v1cex)
I'm guessing that you are using an internal wastegate mounted at the turbocharger...correct? You might want to check if the W/G flap is not messed up.
if i was you i run it off the wastegate but keep in mine i don't know if you have a internal or external wastegate and see what ur boost is.if you still have the same problem then its ur wastegate
Modified by lsvtec300 at 10:08 PM 2/24/2008
could it be that the lil 14b is just dieing?? is it a junkyard turbo? any smoke from the turbo after hard passes?
Re: wont build all 8 pounds (blinx9900)
my first thought was the little bastard was dyin too... no smoke or anything... i am about to have sls make me a manifold for a big 16g or somethin and build the block i guess...
but to answer questions ya it is internally gated and to make sure the stock setting on the internal gate is 8 psi?
is your bov set too soft and leaking in boost? i had a similar prob like this and it was my bov set too soft? adjusted and viola back to 10lbs from a weak 5-6
also check your inlet air filter maybe starving the turbo inlet for air at boost..hope this helps
Re: wont build all 8 pounds (JACER63)
well i think it is too hard because the bov doesnt blow off unless i have at least 3 to 4 pounds built...
hybridcrx
07-23-2002 08:07 AM
