Tial Wastegate problem...opens and car falls flat...
Old Jun 19, 2005 | 01:54 PM
flarinpnoi's Avatar
Default Tial Wastegate problem...opens and car falls flat...
99 GSR Drag Turbo
I installed a brand new 38mm Tial, but changed the spring to the red...boosting 7psi...
As soon as I hit 6000+rpm my car seems to just die down....and the wastegate opens up real loud....
Does it Matter how the spring is installed..could it be upside down? and could that be the reason....?
Old Jun 19, 2005 | 01:55 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Tial Wastegate problem...opens and car falls flat... (flarinpnoi)
what sort of fuel management are you running?
if its the fmu i would expect that to happen. because you are running more boost, the fmu is gonna dump even more fuel casuing the motor to bog and lose power
how are the vacuum lines hooked up to the wastegate?
Old Jun 19, 2005 | 03:02 PM
flarinpnoi's Avatar
Default Re: Tial Wastegate problem...opens and car falls flat... (wantboost)
im just using a the vortech fmu and b&m regulator...
What i did wast just replace my 35mm with a new 38mm and put the old spring in the 38mm.. i never had any other problems...
Old Jun 19, 2005 | 03:41 PM
project dc2's Avatar
maybe cuz the red spring is only 5.8 lbs and not 7
Old Jun 19, 2005 | 04:10 PM
flarinpnoi's Avatar
oopps forgot to add..that im using a Profec B boost controller
Old Jun 19, 2005 | 04:17 PM
do you know if you're hitting full boost ?
Old Jun 21, 2005 | 09:42 PM
flarinpnoi's Avatar
Default Re: Tial Wastegate problem...opens and car falls flat... (project dc2)
yea..im hitting 7psi exactly on my gauge....
Old Jun 21, 2005 | 09:47 PM
flarinpnoi's Avatar
Is there a possiblity that the rubber skirt is pinched?
Old Jun 22, 2005 | 05:45 AM
z6's Avatar
z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flarinpnoi &raquo;</TD></TR><TR><TD CLASS="quote">yea..im hitting 7psi exactly on my gauge....
</TD></TR></TABLE>7 on an autometer gauge?lol
ctownintegra
Jun 27, 2006 02:33 PM
LilCivic04
Jul 12, 2005 10:25 PM
_Cyclone_
May 4, 2005 02:32 PM
1tyme
Apr 6, 2003 05:47 PM
Mr.DC2TurBo
Dec 1, 2002 07:08 AM
