Driving to get downpipe welded.
Old Mar 29, 2004 | 12:24 PM
Pikachu's Avatar
Default Driving to get downpipe welded.
Ok my setup is basically done, all that I have left to do is to drive it to the nearest muffler shop. Problem is, the shop is 3 miles away... It's going to run open DP the entire way. I also don't have the o2 sensor plugged in due to the fact that I was running it without a cat and the bung was welded into a section of the header. So it's going to be running open DP and running really rich cuz the o2 sensor isn't plugged in. Now, what problems do I face doing this? Besides running a really loud car. I just don't want anything bad happening to my motor.
Old Mar 29, 2004 | 12:46 PM
TeamCracka's Avatar
Default Re: Driving to get downpipe welded. (Pikachu)
It's not bad at all. I've been running open downpipe for weeks and the only thing I notice is the turbo spooling fast and some noise that isnt a big deal
Old Mar 29, 2004 | 12:51 PM
Rod.'s Avatar
I had to drive 10-15mins to a muffler shop without a downpipe. IT was loud as **** but nothing was wrong with my engine. Pulled hard after I got the exhaust and downpipe
Old Mar 29, 2004 | 01:03 PM
Pikachu's Avatar
Thanks guys. I was afraid that without the O2 sensor hooked up, the fuel would be flooding the engine causing some problems. But there shouldn't be any right?
Old Mar 29, 2004 | 01:05 PM
TeamCracka's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. I was afraid that without the O2 sensor hooked up, the fuel would be flooding the engine causing some problems. But there shouldn't be any right?</TD></TR></TABLE>
It'll be fine, but yes it will run way rich. It wont hurt anything but yeah you dont want to be driving around in open-loop mode for like weeks, it'll cause super carbon buildup everywhere and yield shitty miles per gallon
Old Mar 29, 2004 | 02:16 PM
5STAR3's Avatar
Default Re: (TeamCracka)
do you mean open dp or no dp.
because the title says to get the dp put on.
if you dont have a dp, i would highly suggest you do not drive it.
Old Mar 29, 2004 | 02:55 PM
tilt's Avatar
ive driven open dp(na) and no dp (turbo) both times i didnt have any problems.
Old Mar 29, 2004 | 03:45 PM
ExVtec's Avatar
just be careful and take it easy....don't overrev....not good on your exhasut valves without the pipes installed....aka burnt valves.....
Good luck..
Old Mar 30, 2004 | 04:25 AM
Pikachu's Avatar
Nah, I'll prolly be driving incrediably slow to the shop.
ebpcivicsi1234
Jan 22, 2005 08:55 AM
91_civicsi
Jun 21, 2004 12:13 PM
nonvtecD
Feb 13, 2004 06:20 AM
spencedogg
27
Nov 20, 2003 04:20 PM
racinskittle
Oct 26, 2003 08:36 PM
