Drag kit Question
Old Feb 5, 2002 | 04:39 PM
R-1303's Avatar
Default Drag kit Question
Gettin drag kit this friday....going with upgrade tial wastegate, 2.5 downpipe into a hight flow cat..from cat back custome 3" piping into apex N1...will i get any boost spikes?? this is for a Type-R and can i still rev up to 8400?? at 4-7lb boost with any problems??
Old Feb 5, 2002 | 05:15 PM
maxim's Avatar
Default Re: Drag kit Question (R-1303)
Have you made the proper adjustments to lower the compression on your car. To be safe you should also retard your timing 2 or 3 degrees. About boost spike, I have yet to see any with my EX and I have the exact exhaust mods that you do(high flow cat,2.5" downpipe, Tial 35mm, and Apexi N1 exhaust).
Old Feb 5, 2002 | 06:45 PM
threatcon13's Avatar
New User
Default Re: Drag kit Question (maxim)
you shouldnt get any but keep an eye on the gauge .
Old Feb 5, 2002 | 08:02 PM
Type-ARR's Avatar
Default Re: Drag kit Question (turbo01gsr)
I have a custom kit on my R w/ the Delta gate and it boost spikes from 5 to like 9psi at high rpms, but I have a headgasket to lower compression......still I have to watch the boost gauge and let off it when the boost starts to creep. It really handycaps (sp?) my car because Im yet to feel the full power of my turbo, but from what I have heard you should be safe with the tial gate, which is what Im going with soon. I have a bit more play with the boost spiking then you would at stock compression so if it spikes just get off it.
Old Feb 5, 2002 | 09:18 PM
R-1303's Avatar
Default Re: Drag kit Question (TurboR481)
thanks people but can i still rev to 8400 safely?? or will it spike?? or will i run to lean for those high piston speeds of a 8400 rev??
pleaz respond....thanks R-1303
TOP*SECRET
Mar 19, 2005 01:51 AM
DD_JonnyLee
Feb 3, 2003 10:04 AM
accordexchange
Nov 3, 2002 12:31 AM
teamrocket si
Feb 28, 2002 04:15 PM
InfamousRS
Oct 15, 2001 11:22 AM
