dont plan to boost much so is a Missing link on a sohc turbo fine on stock fuel management and ecu?
Re: dont plan to boost much so is a Missing link on a sohc turbo fine on stock fuel management and e
tou can get DSM inj, and a TE setup for the same price or cheaper than an FMU and missing link
You dont really want to do that.
If you put a missing link on stock everything and turbocharge it the MAP sensor wont read the boost in your intake manifold. Then you boost it, it adds fuel for 0psi while your at 5psi or whatever, you run lean, you blow up.
Not a safe manuever, although it would probably last a couple days.
