missing link problem
Old Jan 16, 2007 | 04:54 PM
NJ VTECpowered's Avatar
Default missing link problem
when i intall the missing link on the throttle body the car wont idle and wont rev, but when i just connect the map sensor without it the car runs and idles great, just messes up when hits boost ? any ideas?
Old Jan 16, 2007 | 04:59 PM
siblues's Avatar
Default Re: missing link problem (NJ VTECpowered)
You need to put in that cigarette filter looking thing in the hole on the missing link then it will idle better.
Old Jan 16, 2007 | 05:06 PM
psikotc's Avatar
what is your set up?
Old Jan 16, 2007 | 05:07 PM
joppe's Avatar
Get your ecu tuned and throw that missing link away. Stock ecu cant understand boost and it goes to limp mode when map sensor see boost. Its only trying to keep your engine safe from stupid users.
Old Jan 16, 2007 | 05:12 PM
siblues's Avatar
Default Re: (joppe)
I ran a missing link for two years on low boost with absolutely no issues.Just keep the boost low and you will be ok and i know tunning the car will be a night/day difference but it will work.
Old Jan 16, 2007 | 05:14 PM
TurbodTegSfaria's Avatar
Default Re: (siblues)
upside down?
Old Jan 16, 2007 | 05:16 PM
joppe's Avatar
I have try it too. I had walbro + FMU +aem frp. 3-4psi it was good, 7 psi afr goes to 16. Even basemap chipped ecu is better than missing link / check valves. NJ VTECpowered go to http://www.pgmfi.org
Old Jan 16, 2007 | 05:21 PM
siblues's Avatar
Default Re: (joppe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joppe &raquo;</TD></TR><TR><TD CLASS="quote">I have try it too. I had walbro + FMU +aem frp. 3-4psi it was good, 7 psi afr goes to 16. Even basemap chipped ecu is better than missing link / check valves. NJ VTECpowered go to http://www.pgmfi.org</TD></TR></TABLE>
I agree he can even try Xenocron he is in New Jersey too
Old Jan 16, 2007 | 06:17 PM
what cigarette filter thinggy?
Old Jan 16, 2007 | 06:18 PM
Default Re: (NJ VTECpowered)
the bottom side has like a cone looking and there is just a hole on top for the map right?
Old Jan 17, 2007 | 08:22 PM
hold your breath's Avatar
you must have a peace of **** missing link. How I know? Cause everytime you hit boost the map sensor is reading so much forced air which the map sensor throws a code to the ecu and the check engine light comes on. This means you are in limp mode. Get a blox missing link or a 3bar map sensor. stock map sensors with a missing link only hold 11psi max until limp mode. anything over 11psi get a 3bar map sensor. hope this helps.
Old Jan 17, 2007 | 09:29 PM
iBrandon's Avatar
Default Re: (hold your breath)
ur missing link is an Engine Management system....Ditch those if you can..and get an ecu tune...u engine will run 100 times better..
Old Jan 17, 2007 | 10:06 PM
ABK's Avatar
ABK
Default Re: (iBrandon)
dump the missing link, and fmu. Buy some dsm injectors, and get you ecu chipped with a base bin file that somebody used. You car will run better and you will have less chance of blowing up. or spend $400 more and have somebody tune it for you.
standbackimapro
Jun 8, 2008 11:10 PM
D16-t_coupe
Dec 2, 2007 04:19 PM
ROCAFELLA2049
Jun 29, 2006 09:24 PM
spark plugs.
May 11, 2004 09:06 AM
Turbohatch
Jul 2, 2001 10:35 PM
