does ic piping size make a difference?
Old Dec 10, 2002 | 09:30 AM
Wo-Nelly's Avatar
Default does ic piping size make a difference?
I'm about to do some rerouting of my ic piping (drag2 kit circles the engine twice and the car once) and I was wondering if I should go with a 2.25" or 2.5" pipes. Would there be and noticable differences between the two? I believe it is 2.25 right now.
Old Dec 10, 2002 | 09:38 AM
mos's Avatar
mos
Default Re: does ic piping size make a difference? (GottaLude)
It won't help you much unless you are making like over 350hp. If you are making lower power levels it might have the effect of adding a tad bit more lag without noticable benefit.
Old Dec 10, 2002 | 10:44 AM
Wo-Nelly's Avatar
Default Re: does ic piping size make a difference? (mos)
so if I plan tohit 350 someday I should go with the bigger pipe?
Old Dec 10, 2002 | 10:47 AM
PM-Performance's Avatar
i plasn on hitting about that if not more in the future, im sure you will be more than fine with 2.25 piping . im just doing reg drag piping on my car.
Old Dec 10, 2002 | 11:36 AM
fastludeh22's Avatar
Default Re: does ic piping size make a difference? (itr206)
whats the benifits/losses of big pipeing on say a 25+psi and 4-500 whp?
Old Dec 10, 2002 | 11:40 AM
Default Re: does ic piping size make a difference? (fastludeh22)
noen that i can think of on that high boost, but onlower apps the bigger piping will make a little more lag . if your gonna boost that high then go 2.5
Old Dec 10, 2002 | 12:25 PM
Wo-Nelly's Avatar
would having 2.25" pipes limit me in anyway? I mean its something that can be maxed out, but when?
Old Dec 10, 2002 | 01:08 PM
01ITR#700's Avatar
A friend of mine makes 450whp with 2.5" piping all around on his drag CRX. IMHO 2.25" is capable of the same amount of power with no real major hinderance, but minor loss perhaps.
M
Old Dec 10, 2002 | 01:11 PM
Howitt's Avatar
Default Re: does ic piping size make a difference? (01ITR#700)
we used 2" piping on my buddies junkyard turbo setup and that seemed to work fine but hes only putting out like 230
boostedb20ek
Sep 26, 2009 12:15 AM
VtecAdil
Oct 7, 2004 03:36 PM
phreakmang
Jun 23, 2004 07:04 PM
steeliecivic
Oct 2, 2003 08:13 AM
Smashback
Feb 27, 2002 12:46 PM
